Rear lowering kit and belt tension?
As far as the OP quesiotn. I think it would make it a little tighter. Your moving the shock back which is moving the swingarm up..
The only way that it would stay the same is if the drive pulley and swingarm pivot were concentric. In practice the change in tension is tolerable, obviously.
The SG has a different belt tension to the RK + EG etc, if you are lowering your bike just use the SG number in the manual.
DefaultKnow this is old chat, thread or whatever but I just replaced my 03 Road King junk air rear shocks with non aired slammers which drooped its *** end 1.5 inches. Checked for bottoming out on bumps but overlooked the alignment on rear belt. After riding about 50 miles over a couple days with teen daighter on back noticed a squeaking from rear on decel & left turn. Stopped could see where belt was rubbing rear tires top sidewall checked belt tension was sloppy loose. Replacing shocks & other stuff never touched rear axle, or cams that adjust tension. Lowering does cuz belt to get more play with just me it seemed fine but both od us lowered stance more.
