Batwing Fairing Angle
You have a good point here and I have wonder the same thing. I don't want to tilt the whole fairing, but the lower gauges need to point upward.
Example: On my batwing the air temperature gauge is useless. Trying to read it in the normal sitting position, it always looks like it is reading 5 to 10 degrees higher than it really is. I sat on a Road Glide with the "shark nose" fairing and this in not an issue at all. All of the gauges are angle so that you can read them.
My Memphis Shades batwing
has adjustable angle mounts. I'm unsure as to how the HD fairings attach to your bike but you may be able to add shims where the fairing attaches to the mounts. Before I got the adjustable mounts I had used rubber plumbing washers as shims to push the fairing forward at the top of the mount.
I've noticed that with some aftermarket fairings. Some of them are tilted forward a bit, which just looks funny.
Thanks for the suggestion. I don't know why I didn't think of it. I never understood the reason for the air temp gauge in the first place. The bike should come standard with the oil temp gauge anyway. Another MoCo way of milking some more money out of us.
