Front fender yellow marker light not working
08-17-2010 | 08:48 PM
pulled bulb and checked good but no voltage to socket key on. Clue me in on where to check next? 2000 FLHT Thanks
08-17-2010 | 09:21 PM
Check for a broken or tire rubbed wire inside the fender. Had it happen on my 04, one of the retainer clips had broken off insise the fender.
08-17-2010 | 09:27 PM
Check where it plugs in up behind the passing lamps behind the fairing.
08-17-2010 | 10:45 PM
Wire rubbed by tire on left side of front fender. You'll have to splice a new wire into the set up to fix. When it happened to me, the wire popped out of the retainer clip. I replaced the clip along with the wire. Front wheel has to come off to make this repair doable.
08-17-2010 | 11:15 PM
I will check the wire back under the ft fender thanks.
08-18-2010 | 12:50 AM
as alot ofothers said check under the fender, it happens alot, lousy wire clips
47Norton
09-12-2016 12:15 AM
longlakehouse
Electrical/Lighting/Alarm
10-23-2009 07:23 PM
CardsFanOne
12-05-2007 10:20 AM
CardsFanOne
08-27-2007 11:13 AM
Mikeeeeeeeeee
11-02-2005 11:30 AM
changing ,
classic ,
clips ,
davidson ,
fender ,
front ,
harley ,
inop ,
king ,
light ,
lights ,
marker ,
road ,
ultra ,
working
