installed apes on my 09 road king. rode a thousand miles, and now have no blinkers,cruise, or brake light. checked fuses and all connections, still doesnt work.where do i go from here, and am i missing something?
Back Track Again ! I would think it is related to the extended harness.Always start at the source of power and work your way through the circuit.Good Luck!
thanks, gonna go thru it again. weird combination of things wrong tho. wonder if all these that have gone out is all on the same plug? any idea anyone?
Probably has to do with the brake light wiring. Cruise disconnect and blinkers are aligned with the brake light. Could be as simple as the brake light bulb.
wel thought i had it fixed. changed out fuses even though they looked fine. bingo,everything worked! assembled everything back together , test ride, doesnt work again! pissed off! got a short somewhere i think
