need help with wiring issue
Old 08-17-2010 | 07:54 PM
roadgliderick's Avatar
roadgliderick
check the wires at the grips they could have been pinched
Old 08-17-2010 | 08:05 PM
All Aces's Avatar
All Aces
Had the same happen to me and I finally had to peel back the black shrink tape and found a pinched wire from the housing.
Old 08-17-2010 | 08:59 PM
wing_rdr's Avatar
wing_rdr
Like everyone else stated, check for pinched wire - been there, done that, have the T-shirt. I had my radio and left side handle bar switches doing all kinds of funny stuff until I found the problem at the switch housing case.
Old 08-18-2010 | 07:13 AM
rh8234's Avatar
rh8234
Originally Posted by b duncan
wel thought i had it fixed. changed out fuses even though they looked fine. bingo,everything worked! assembled everything back together , test ride, doesnt work again! pissed off! got a short somewhere i think
Dude - open those switch housings and look carefully - your symptoms are clasic for pinched wire in the housings. Like someone elsa said, you may need to peel back some plastic conduit to find it.
Old 08-18-2010 | 05:57 PM
b duncan's Avatar
b duncan
2nd Gear
thanks for the good advice guys, gonna take a look at it in awhile.
Old 08-18-2010 | 06:34 PM
1HarleyGuy1's Avatar
1HarleyGuy1
Don't know how you're doing with the problem but I have also been having some "electrical" issues. The key light icon will come and stay on from time to time.
I sought out some advice from a very well respected member here and in addition to checking different parts, he also suggested downloading any error codes the system may be holding.
Good luck
1HarleyGuy1
SFinley70
06-02-2019 04:10 PM
cityworker
07-26-2013 02:59 PM
iupsig97
04-16-2013 07:50 AM
Joker659
03-19-2012 07:30 PM
bayouboy52
07-12-2009 01:48 PM
Quick Reply: need help with wiring issue
