Installed SE Compensator under warranty?
Was it a terrible roaring "dry bearing" sound when in neutral and clutch out? My money is on the inner clutch bearing and race. A buddy pulled in from Boston and his was OK with the clutch pulled in but in neutral and clutch out it sounded like it was coming apart!
Mark
Mark
If there's no ancillary damage, I'll be very happy! And, to the other poster, no I'm not looking for stealer to pay for an upgrade to SE components, but they should let me pay the price difference for the parts, and then do the install work under warranty (either way, they have to spend X hours to complete the install of parts).
Thanks all!
Harley is also saying there are no issues with the stock compensator in the '07-'0-10 models. Anyone who has spent some time here in the Touring forum likely knows better.
Will need an expert to weigh in, but it looks like it doesn't; went through the 2010-Model Tech Highlights and couldn't find a reference one way or the other and then looked in the P&A catolog and it doesn't state as standard equipment in the SE Compensator description. (2010 P&A states standard equipment on Trikes, 2011 P&A catolog states standard on all 2011 Touring and Trike models.)
Generally it would be impossible to miss. Sounds like a box of loose nuts and bolts in the bottom of the engine. In my case, I had the compensator come loose on my 2003 Fatboy while on a long distance trip. Took it to a dealer nearby from when the sound started. Inspected the inside of the case around the compensator (marked up abit), retightened the compensator nut to the OEM torque specs and I was on my way. No harm no fuss (although it scared the bejeezus out of me while I was riding).
Never had an issue with it again.
Because I think for the most part it has been proven that the OEM compensator is under designed for the job it needs to do. Hence all the knocking at start up and marbles in a jar sound running down the road. A night and day difference since I've had a SE compensator installed.
