Installed SE Compensator under warranty?
Hopefully the dealer will just charge you his cost of the diff between the OEM and the SE one. Shouldnt be over 100 bucks. Not worth getting your undies all balled up. Just tell him to do it. My friend had his upgraded when the OEM pooped out, the dealer was going to charge him 125 bucks but has not since billed him.
Still hoping someone can tell me: why does Harley say that I cannot have the SE, but they WILL install the compensator from the Tri-Glide, and yet the P&A Catolog states that the SE compensator is standard on the '0-10 and '0-11 Tri-Glides? Am I actually getting a SE compensator, maybe with a different part number, so Harley doesn't have a run on owners of '07-'0-10 owners wanting the SE? No clear answer or explaination so far...
The problem is that my dealer won't do it all, unless I pay the entire cost of replacing the OEM compensator. Dealer says that if Harley is picking up the labor costs, they HAVE to install the compensator that they are told to install, no switching, no upgrading. Period.
I don't see Harley maintaining 3 different compensators for their Touring bikes. Actually, they discontinued the basic one and install the SE one on all 2011 models so it must be the same, like the P&A catalogue says.
Ask him what part # he's going to install. I bet it's 40274-08 which is the SE one.
Why does he say you can't have the SE one? Cause he doesn't seem to have a clue what he's talking about. He wouldn't be the only dealer like that.
At this point, I can't fault the dealer, the information isn't off the cuff; when he called me, it was only after him contacting tech support three days prior, in dealing with my issue and concens. He tells me that it's tech support that has given him all this information and specific direction on what they can do.
Richard, I think your dealer is blowing some smoke for some reason because when my compensator came apart on my bike a few months back my dealer replaced the OEM version with a SE version all under warranty. I was told specifically several times that the MOCO is making this the standard warranty on all bikes that need a compensator replacement due to the OEM version crapping out. I haven't had any problems sense. I've also read other posts that had the same thing done under warranty. I would think that the trike version is a SE so I wouldn't hesitate to go that route if that's what your dealer wants to do.
I think my compensator just blew up today... had to have bike towed to dealer this afternoon. Out of the blue, the lower engine started to make a hellacious noise... limped 1/2 mile to office and stopped bike.
Explained problem to dealer and his first comment was that it was probably the compensator. I will definitely look into this SE version and talk to dealer about it before letting them put anything else into the bike.
I'm worried that this might have damaged other internal parts. What else should I be asking here? Sorry, but I'm not mechanically inclined.
What pisses me off most is that the bike is only 2 months old, 5,500 miles and just got back from Sturgis (thank God it didn't blow up out there!). Also, just had the 5,000 mile service done by stealer last Friday (200 miles ago).
Thanks for all the great information here!
My 2010 Street Glide came with the SE compensator in it from the factory. When I did the stage II 103 kit I talked with the builder about the upgraded comp as part of the package and when he tore into the primary it was already installed.
