whats best for a quieter transmission
08-15-2010, 03:38 PM
They should specify on the labels and put it in one bottle. They are the same price. Thanks
08-15-2010, 04:35 PM
I ran Amsoil 75-140 severe gear in my 07. It was a lot better. My new 2011 limited is quiet as a mouse w/ Hd oil in it.
Mark
08-15-2010, 04:45 PM
Quote:
Originally Posted by
VETERAN75
Yeah, I was thinking the same thing.
08-15-2010, 04:47 PM
dawg
Redline Shockproof Heavy
Seems to be what a lot of folks are using...i will probably try...
08-16-2010, 09:50 PM
I used the V-twin with Shockproof, dark bottle, Redline website recommendation. Found it 20 minutes away at Cycle Gear shop.
08-16-2010, 10:29 PM
I have used Amsoil SVG in two different weights and Redline Heavy Shockproof.
The Redline is the quietest (by a smidge) in my 09.
I have heard good things about the Belray , but haven't tried it , will probably stick with the Redline.
JMHO
Mick
08-17-2010, 01:49 AM
redline shockproof heavy, and use the B&M trickshift trans fluid in your primary. it's like night and day, the difference.
08-17-2010, 04:33 AM
I just swapped out the Syn3 from my trans & primary on my 09 RG and used Redline primary fluid and trans fluid w/shockproof. The primary fluid looked like ATF and the trans fluid looked like "pepto bismal"...thick and pink. Have not had a chance to ride since the change.
08-17-2010, 04:56 AM
Mobil 1 V Twin..
It's probably 75% quieter now
The 5th gear noise is slowly going away
08-17-2010, 06:28 AM
