Twin Cam 88 upgrade to 107 or 110
Old 08-19-2010 | 06:35 AM
Mike's Avatar
Mike
Axtell also has big bore kits, and can machine your cases and heads.
Old 08-19-2010 | 08:28 AM
VETERAN75's Avatar
VETERAN75
Well since your going to put money into a kit to go past the 98" and have to move to a bigger crank you may as well buy a crate engine in the size you want. The cost will be pretty close to the same after it is said and done.
If you just more go I would stay 113 or under. Anything over a 113 you need a track to use it all. I have the mild HQ107ST and still don't use it's full potential but the torque is very nice to have on the highway riding 2up.
S&S hsa the new T111 on sale for around 5500 rady to go, carb, gear drive cams, etc.
http://www.sscycle.com/product/cart....detail&p=21059
check it out.
Just run some numbers and you may save time and money with a crate. good luck
companies with kits. GMR, Hillside, Tman, Headquarters(go to protwin.com), and many more but thats a few.
Old 08-19-2010 | 09:20 AM
Scorpion07's Avatar
Scorpion07
Hogchief, you haven't chimed in much since you started this thread. Are you even interested in splitting/boring your cases? Or a crate motor???
If not - the motor heads in here can give you the advice you need to just keep your lower end stock and still get a great running "98".
Old 08-19-2010 | 11:52 AM
Road Rat's Avatar
Road Rat
I have a 1999 Road King with the MM fuel injection. Are crate motors an option for us with older FI, or is it just too costly to bypass?
Old 08-19-2010 | 02:07 PM
VETERAN75's Avatar
VETERAN75
Yes you can get a crate for fuel injections. Just will cost more than one with carb. You can buy a new crate motor thru the moco. Talk o your local dealer about they're reman engine program. May be something you can do this winter.
http://www.harley-davidson.com/en_US...s/engines.html
Old 08-19-2010 | 03:39 PM
inverse121's Avatar
inverse121
check it out.
I'd say that's a winner right there.
I've been thinking about it myself.
Old 08-19-2010 | 05:56 PM
inverse121's Avatar
inverse121
Old 08-19-2010 | 06:27 PM
Bago's Avatar
Bago
[QUOTE=Harleypingman;7164827]In reply to the original post, vendors of excellent 107 kits include: Head-Quarters and GMR.
You will need to split the cases to install a 4 3/8" crank for a 107, or a 4 5/8" crank for a 120.
You don't need to change the crank for a 107 build.The stock 88" 4.000 crank will work with a 4.125 bore.
Old 08-22-2010 | 10:22 AM
HOG CHIEF's Avatar
HOG CHIEF
Guys, thanks for all the very good info....looks like lots of options out there.. Talked to the guy where I am going to have the work done, first thing out of his mouth, was go with S/S, reputable, back their product etc. Also talked with another friend of mine who has the same type bike and did some more research along with you all posted... Looks like I may be leaning towards going to 97ci, replace heads/piston with S/S 97, change out the cam to gear driven cam, either S/S or someone else, most likely Sampson True duals and some carb work... I think that will give me the power and torque I am looking for...I really appreciate the post, gave me a lot of areas to research....good info from all
gartec81
03-10-2015 11:36 AM
my55shoebox
12-20-2014 04:49 AM
MrRocket
08-05-2012 11:16 PM
Rolling Thunder Cust
10-08-2007 10:27 AM
frogwash
10-01-2006 03:57 PM
