anybody install the Kuryakyn panacea tail light kit?
I bought the kit and use it regularly, I do have the factory security installed and did have a burn out of an equalizer. They (Kuryakyn) tech assist realized the symptoms and hooked me up by rushing the correct equalizer to me. The system has worked since then I use my turn signals all the time and emergency flashers short periods of time occasionally. It does all the flashing features but I would like a brighter set of lights(those new police LEDs are BLINDING - my stop light should be too). It may be a reason to upgrade to another brand of system later. but for now there has been no further problems with two and a half years of DAILY use.
I have the panacea tail light on my '09 Ultra as well as LED turn signals both front and rear. The Kury Panacea equalizer is crap; it overheats very quickly and thus will burn out if you use the flashers. I purchased a heavy duty, non-heat generating load equalizer from Ride Time Technology http://www.ridetimetechnology.com/badlands_le3.htm and have not had any problems since.
By some chance, did you ever have the security key light on the speedo flash on and off with the flashers? I have the "correct" equalizer but have had this problem since day one. (3+ yrs now)
I'm pretty well done with Kuryakyn products. I had a set of primary covers for my dyna which tarnished and couldn't be brought back, got another set and the same thing happened. My neighbor gave me a set of their iso wings touring pegs when he sold his FLHRCI and I used them for a while liked them but they always needed adjustment. I bought a new pair and the same thing, only worse. I bought a set of lizard lights at Sturgis 2 years ago and it needed repair about 3 months later.
I put the Kury Panacea Tail light and LED turnsignals on last March. After install I moved the bike without my key fob and the security system flashed the tights one cycle. Didn't notice anything wrong untill I road the next morning and my left turn signal would not work. Removed the seat and the equalizer was so hot it burnt my fingers. I waited for it to cool down and removed it. The signals worked fine after that. I haven't used the equalizer since and everything works fine. I have had no issues with my security light either.
I caught up to a bagger in front of me thinking it was a `10 because only the outboard lights worked. Got closer and saw a panacea T/L in the middle. The rider pulled into a gas station I was filling up in and I told him the middle T/L didn`t work. He turned it on and it worked but dim. He acted like I was ef`n with him. I`m running a much brighter T/L but don`t want to advertise it as it was a hassle getting it straightened out. I do use a badlands load eq.
oldbagr
Thanks for the reply.
Do you have the security module? If so when the load equalizer burns up does it cause problems? On of the reasons I do not want to install it is the claim in red on the instructions that if the load equalizer burns up you loose the turn signals.
Also there are instructions to cut wires in the wire harness? Not too keen on destroying the wire harness.
I do have this problem. I guess I have learned to ignore it. It does not seem to be causing any other issues.
