Big bore or cams???
Ok this is just a question for my own learning...with out doing
Which will produce the most power, changing cams with out doing a big bore install, or doing a big bore install with out doing cams, and just to make it interesting what about with and with out a stage 1?
Thanks
Terry
Thanks
Terry
I am only going to port a set of heads and put in a set of .018 head gaskets and that's going to be it until the engine wares out.
Thanks again for the replys.
Ok so now another question, I know my bike has a stage 1, but for what ever reason it has stock pipes, wondering if the original owner took the free flows with him, anyway ok it is a 99 RKC, I have two friends with I think 04 peace officers addition, anyway one is a Road King bone stock, the other is an electorglide classic with a big bore kit, I can walk away from the stock Road king, but the one with the Big bore kit can pull away from me after the end of second gear, yes we did a drag race to see if we could tell the difference, so would a stage one and the lower gearing of the 99 make that much of a difference over the 04 stock?
Also is there an easy way to check and see if you have stock cams or not?
Thanks again
Terry
Thanks again
Terry
