Is 6 quarts enough for all three holes?
Whatever you decide to use it will be a total of 7 quarts and you will have leftovers in 1 bottle...
Primary...don't use regular car oil....use ATF, V-twin or primary fluids....Car oil "MIGHT" make you clutch slip....This is if you use your bike like i do...Loaded, Hills, Hard starts....I use car oil in my motor, primary fluids in the primary and gear oil in the tranny...I have also used 20W50 V-twin in all 3 holes and to be honest i couldn't tell the difference at all...50k miles later still sounds the same.
Received 75,786 Likes
BTW: I would rather run a little light than too full of it.
Just trying to help...I guess the owners manual and all of the service manuals are wrong...Being a full qt. light in this heat will lead to premature thermal breakdown of the oil...I guess you save a ton of money running a qt. low...Good luck...The heated grips are great for winter riding my bike rolls year round.
If not, then you are over filling your crank case, every time. BTW;The OM says 3.5, not 4, but beings how you have heated grips and ride year round, I'm sure you do.
Quantos
Since this is the 1000 mile check up, I agree that the dealer should perform the service. The rest you can do by yourself but that's not what you asked.
If you only give the dealer six quarts and he says he needs 7, then he might add some Syn 3 to your engine. So don't give the dealer any reason not to use your oil, and ask for the 7th qt back, used or unused.
Do you measure the amount of oil that comes out of your bike, and then put the same amount back in that came out?
Look at the bottom of page 1-15 in your 2009 Touring Service Manual and tell me what it says.
My owners manual also states 4 qts for the motor. Mine read full at 3.5 when warm and puked some out the filter. With about 3.25 qts in the motor the dipstick reads about 2/3 full and doesn't puke....
If this.. http://www.castrol.com/castrol/gener...tentId=7032644 is the Castrol oil you have, I don't think their would be any issues in your motor and primary. I'd still go 75w-90 or 75w-140 syn for the tranny.
