SE Compensator Review (A bit lengthy)
Old 09-06-2010 | 11:16 AM
Faast Ed's Avatar
Faast Ed
Originally Posted by 09ultraclassicrider
Thanks for the right up. Someone on here told me that while you were in there and you have the cash you might as well change out the the chain tensioner to the wedge style hydraulic tensioner from southern oregon hot bikes. There will be no clunk issues when starting (SE compensator) and no whining issues (wedge tensioner) with the chain because the HD unit has a tendency to ratchet up too tight and then it cannot come back down because of the ratcheting teeth, but the hydraulic one has no teeth so it constantly moves up and down. If memory serves correctly the tensionor was $100 ish.
I had to modify my SOHO wedge to get it to work properly, and a year later it is still performing well. Also, I have heard that they improved them since (but I havn't seen a test on the "improved" version).
Mine would bind up until I added a spring behind the wedge. All good now.
  #62
Old 09-06-2010 | 12:02 PM
profp's Avatar
profp
Thanks for the quick replies Nemick, HDV-glide, Faast Eddie, all. I measured the stack and the splined shaft with extension and determined the springs must be compressed about 1/3 inch by the bolt before it bottoms out and can be torqued. Clearly, there will be no slack under that kind of tension.
It still curious to me that it looks like there is effectively a "frozen" compensator under all but heavy torque loads (e.g. drag racing shifts). Ah well, it works and that's the bottom line
  #63
Old 10-12-2010 | 09:06 AM
Hinzy's Avatar
Hinzy
Originally Posted by nemick
I have a 2009 Ultra and I have been struggling with the amount of noise my engine makes, cold or hot. After seeking some input here, I went ahead and purchased an SE compensator to see precisely what difference, if any, it would make. My main goal has been to reduce the perceived noise coming from the bottom end of my engine. My engine, hot or cold, usually sounded like it was a bag of bolts and ready to explode under aggressive acceleration. It was to a point where riding had become less than a joyful experience. Many have said that this rattling, clanging, banging and buzzing are normal and an integral part of the Harley mystique, but it was getting a bit too much for me.
I was able to purchase the SE compensator at my dealers Open House and get a 20% discount, so that was cool. I do my own wrenching and set about putting this thing in. Based upon measurements I found on thread here, I made my own sprocket locking tool and the only other unusual tool I needed was a 1 3/16th socket. I had a 30mm socket and this worked fine.
First off, let me state that the physical differences between the stock compensator and the SE version are massive. Just looking at them side by side, you would have a hard time imagining both of them doing the same job, let alone fitting in the same space. I followed the manual and everything came apart as expected until I tried to remove the stator housing. The diameter of the housing is too large to simply slide off the crank spline, as there is extra thickness to the inner primary case at this point. I was expecting this because of other posts here and I was also expecting to have to do some grinding. However, I loosened the 6 inner primary bolts by about 4 turns each and achieved enough slack and space to easily remove and replace the new stator housing without any grinding at all.
Everything fit perfectly and went back together with ease. It took me about 3 hours from start to finish.
I took the bike out for a ride and I would have to say that this 'upgrade' cured at least 80% of the problems I was having. I never really had much banging at start up and it wasn't this that concerned me. Starting now however, was quieter and smoother. Selecting gears has improved significantly, with reduced clatter. Riding around, the bottom end of the engine no longer sounds like its ready to fly apart. Acceleration and deceleration are much smoother and quieter too. I put about 200 miles on the new compensator and I am very pleased with the results. It still has the 'normal' top end tapping, but thats another project.
Everyone says it, but I mean it when I say that the SE compensator, in this instance, is by far the best money I have spent on my bike. The joy is back and I wouldn't hesitate to recommend this change. I only hope it does the same for anyone else contemplating the swap.
Neil with regard to the locking tool I will making my own too.
What lenght did you wind up with?
TIA Hinzy
  #64
Old 10-12-2010 | 09:50 AM
vickers1's Avatar
vickers1
TIA Hinzy
I would like to install mine too but don't have enough info on making the tool. Any help here would be greatly appreciated (pictures help too).
  #65
Old 10-12-2010 | 11:01 AM
captainjack's Avatar
captainjack
http://www.harley-davidson.com/gma/g...2&default=none
its the flatbar between the sprockets discounted @ zanotti or chicargo harley
  #66
Old 10-12-2010 | 06:06 PM
Mick's Avatar
Mick
For the locking tool , I used a piece of 1.5" x 1/4" flat stock steel.
The length I made it was 5 7/8" long (6" would be fine).
A width of 1" would work also , I just happened to have 1.5" wide available.
The ends have to be radiused so as not to mark the tooth base of the sprockets under pressure.
The SE comp has to be held by it's own outer hex while it's main bolt is tightened.
You only use the tool to remove the stock comp.
Mick
  #67
Old 10-12-2010 | 06:56 PM
Pine Tree's Avatar
Pine Tree
MODERATOR
Veteran: Marine Corp
FWIW, a piece of solid hardwood (maybe red oak) that's about 7/16 x 1 1/2 x 5 3/4 will work just fine. Round the ends for better fit but not necessary.
Red oak is available in various lengths from places like Home Depot or Lowes and costs about $2 and up.
Deckman
01-30-2022 09:24 PM
LoveHate
11-18-2014 11:36 AM
SteveUltra
10-10-2013 03:17 PM
onionfmr
12-06-2009 09:24 PM
tommyj
11-16-2009 07:42 PM
Quick Reply: SE Compensator Review (A bit lengthy)
