cold vs. hot oil level?
Can anyone explain why my oil level when cold is alittle more than half a quart low, but when I check it hot it is to the full mark. I'm using Amsoil 20-50 motorcycle oil. Does the heat make it rise that much or possibly aeration, but I don't see any bubbles when I check the oil hot.
I only put 3 1/2 qts. in it now so I don't blow it out the breathers, if I put the full 4 qts. in, I'm overfull when hot! Is this normal?
