Need a clutch adjustment expert.
Been searching all over the forum for help. Long story short. 05 Road King Police. Since I changed the clutch cable for the taller handlebars, the bike will upshift fine, but downshifting takes a lot of effort, and I can not find neutral unless the bike is shut off. So, I did the clutch adjustment by the book, and several other ways recommended by forum members. This weekend, I thought I had it close. But once I get close t the 1/8 to 1/4 freeplay at the lever, "SNAP", and each time I have to take the transmission cover back off and fix the ramp. Seems like it rolls too far and lets the ***** pop out. I am pulling my hair out. WTF am I doing wrong?
It may not be that, but when I get close to having everything right, pull the clutch lever in, something snaps, and the lever goes to the bar. I pull the side cover off, and the ramp is against the snap ring. It has to be something I am overlooking, or so stupid that I cant figure it out.
I have seen this happen in this situation. the clutch pulls then goes all the way in. Check to make sure that one of the ***** in the clutch actuator (not sure if its called that) hasn't slipped out of place. It will cause the plate to get stuck all the way out at the snap ring. It doesn't take much. Use some grease to make them stick, then reassemble. Make sure the snap ring is good. Check that your cable is hooked up correctly at the lever. Make sure the bike is cold. Loosen the cable adjuster all the way. Loosen the locknut and run the adjuster at the clutch pack out and back in with you fingers until it is finger tight. Work the lever, you should see some motion in the clutch. Repeat a couple of times. Last time run to finger tight and back out 1/4 turn. Lock down, put derby cover on. Adjust cable to width of a nickle play and you should be good to go.
When you get the *****/ramp in place and re assembled, loosen the clutch cable adjuster fully. Then run the adjuster screw in all the way until the diaphragm spring starts to compress. Then back out and do it again until lightly seated. Back off 1/2 to 3/4 turn and lock it down. I'm thinking your adjuster might be too far out and you are taking up all the slack at the clutch cable instead of inside the clutch pack.
There's a good thread over in the Evo forum that describes clutch adjustment, which you may find helpful. Go to #27.
