Brake Lights
08-06-2010, 08:24 PM
Brake Lights
Wife & I went for our 1st night ride on our new 2010 SG and noticed that the brake lights were not working; couldn't tell if they were constant on or not. But there was no response by the lights regardless are what lever was depressed. Are the brake light on a seperate circuit? In other words, is there a seperate fuse soley for the brake lights?
08-06-2010, 08:37 PM
Brake 15A and ACC 15A. Do you have ABS or not?
08-06-2010, 08:38 PM
Quote:
Originally Posted by
dawg
Yes, I have ABS...
08-06-2010, 08:44 PM
Here's a diagram for your 2010 with ABS
08-06-2010, 08:47 PM
Thanks Dawg! I have had a chance to get the manual yet, this is a big help.
08-06-2010, 08:50 PM
Also, are the fuse located behind the lft side cover like they were on my 2005 Ultra?
08-06-2010, 08:53 PM
Have you changed the grips? If so you may have broken the small plastic brake switch in the break lever.
08-06-2010, 08:55 PM
08-06-2010, 08:57 PM
Remove the lens and see if both filiments are lit? Could be simply a faullty return spring on a lever (front or back?).
Ranger12s
Shovelhead
09-30-2017 08:27 PM
Mr.Softy
06-21-2015 09:36 PM
Akkarine
04-02-2012 11:08 AM
cnnesseth
05-13-2011 10:51 AM
BBStacker
10-30-2010 12:17 PM
