compression PSI
Static Compression
It's been 25+ years since I've worked around air-cooled [aircraft] engines. 160# is excellent compression, & would be regarded as 'good' or "serviceable" down to 80# or so.
The real issue is not the total compression, but whether the 2 jugs are within 7-10 pounds of each other. I recall we rebuilt our individual aircraft engines when the compression dropped below 70 pounds or if the jugs were not within 10 lbs of each other.
