Decel poping with pcv
Any one know if it is as easy to stop this with a SE tuner with smart tune as it is with the pc? I changed o the 0 colums with the pc5 and pretty much stopped it but would like to switch to the SE unit and am a little intiminated by it and seem to think i will have trouble getting help with adjustment questions.
Personally, I would never consider switching from PCV to SEST.
Any good reason for it?
The SE tuners are very easy to work with and will allow adjustments of decel enleanment (your popping problem) as well as many other necessary adjustments to properly tune your bike.
More than likely they have a base map that will already have the proper settings which will have you running great with one download.
It amazes me that people think you can take away a very important tuning features on a bike like the O2 sensors then limit you to a very few that can adjust and think they are getting a good tune.
Smarttune
I would like to try the HD tuner with smarttune seeing i have that system too. I have the pcv now and it works but i really hate the way it gets squeezed in on the bike and piggy backed off the ecu. I would like to have the o2 sensors hooked up and try tuning with the closed system. I don't plan on any tuning other than the canned map and smarttune adjusting. This is what i am asking,can i adjust this smarttune system myself with limited computer skills? I adjusted my pcv myself but feel that it is not allowing my ecu to use all its functions properly on the bike.
I just changed my PC5 to the new TTS on my 08 Ultra SE3. What a performance difference. Better acceleration, smoother idle no popping and much smoother and pulls better through the entire RPM range to 6200 RPM and the tach doesn't quit at 4500 RPM like on the PCV. Also easier starting and you can make adjustments to the map on your PC and download on the bike like the Power Commander. Easier to work with and you can do a lot more with the TTS.
Jeffinburlington
37
12-29-2014 11:02 PM
