Touring Models vs Shorter Riders: Solution?
Ok...I've started similar threads about asking for advice on lowering touring models, changing seats, re-padding seats, etc., all with goal of helping me deal with a heavier bike, 5'9" frame, 29-in inseam, a wife who loves to ride with me and my overall lack of confidence when stopping my 2010 Ultra Limited. I've been riding softails all my (Harley) life and I have yet to get comfortable with the bagger. Now I can't go back because my wife would kill me...not for the $$ but for the comfort she has come to love.
I have read many posts with folks in the same situation as I am. Some of you offer advice on changing the seat altogether or doing a full lowering, rather than just the rear as I did, and other helpful advice. But going back and reading the threads again, I have found that many of you haven't really solved the problem I continue to face. For the most part, most of you (and I) hope for improvement over time. So here is the question: Has anyone completely solved the height/weight/stability issues associated with a 900-pound bagger (+ passenger) if you are a shorter rider. Am I just wasting time and money looking for a better solution that might only come if I go back to a softail?
And one last question, some HD dealers have a "Fit Shop," where they can customize a bike to your specific needs. My dealer doesn't offer that but it might be worth a trip to one with my bike if they work. Anyone have experience with that or is it mostly BS to sell additional accessories and seats. HEEELLLLLPPPPPP!
I bought the lower seat and had it modified by MCC. That solved some of the "height" issue but not the issue with stability. It's a combination seat height, seat position and bike weight thing. Perhaps lowering the front will make things better. I sat on an Ultra in NM that was fully lowered and had a new reach seat on it. In the showroom, the bike felt like my old softail, but you never know till you ride.
I am the exact same height as you. Pick up the video Ride Like A Pro V. Your issue is not your height but that you haven't learned to ride that bike. This video will solve your problem. The HD touring bikes are easy to control with the correct techniques that you'll learn. You can also sign up for the class they give in various parts of the country.
I'm 5'8" tall, 160 lbs. I can ride a stock Ultra usually solo but have no problems even with a passenger. I lowered mine 1" in the rear mainly because it makes backing up easier. Wearing good boots (ankle support and good tread on the bottoms) also helps.
Take a MSF class or two, practice slow speed riding solo and with your wife. Keep the RPMS up some, use the clutch and rear brake to control your speed.
If you can be very specific about what situations make you uncomfortable you will get better answers.
Your options are to lower the seat, the suspension or both.
I would start with lowering the seat because that does not affect the ride quality. If that's not enough, I would lower the rear suspension. If that's not enough, I would lower the front too.
Remember, everything is a compromise. Lowering the suspension will affect the ride comfort a little. As long as you can live with the compromise, you are set...
One more thing... Ride more or take motorcycle riding courses. Practice helps a lot.
wobbley
I am about the same height and weight...I also found that during the summer I was riding with my sneakers on. I went back to using my boots,(they have thick heels), and it really helps. Another thing I found is to use the front and rear brake to slow down, but the front brakes really want to make the front end nose dive and make the problem worse, so as I am approaching a stop I will use the rear brake, then left foot down, then hold at a stop with front brake, then right foot down.
I usually find it is worse with wife/and the full load we carry in the tp on the weekends.
