Catalytic Converter
Minnesota never tested in out state, where I'm at. We did have a smog problem in the Twin Cities for a few years, but not since 1999. No testing since 2000.
http://www.dmv.org/mn-minnesota/smog-check.php
I run "modified" slash cut stock mufflers off an '06 Road King (the cat's been removed and about a third of the front of the baffle plus the baffle plates), so my mufflers still look stock from the rear, carry the EPA stamp, are not loud, and have never had a problem when traveling.
I was thinking about getting a 2011. Now I know I have to add $1000 to $1500 to get the bike to sound right, run right, and keep from burning my leg off.
I may rethiink this whole thing and just spend some money upgrading my 2008.
It will be a lot cheaper then buying a new bike and then spending more money getting it to run as good as my old one.
Their is another way around it. If you are handy with tools and dont mind getting your hands dirty. You can keep your stock exhaust and have cat-less head pipe. Any modification you do that removes the cat, will require you to remap the ECU.
Check out this site....www.fullsac.com
I'll keep the old header pipe that has the cat, just in case
but after taking me 4 hours to remove it and install the V&H Power Duals, my hands and wrists aren't able to do it again for quite a while. After I had everything together I took it for a quick test ride and came back to check for loose stuff. Gave the muffler clamp a pull with the wrench and 'twang' Broke the frigging bolt. So I had to take the slip on off just to get another clamp on. Didn't yank on that one too tight. After all this the guy at the dealer laughed when I told him how long it took me and said "we only charge 1 hour to re and re the head pipes' I think I must have looked a little funny while I stood there and just stared at him, then I said "f*#k off", with a bit of a smile of course.
1 hour?? Oh well, I love wrenching on my bike and I always learn something new. I'm not so nervous tightening a bolt into aluminum anymore. Sure stripped a lot on my metrics over the years. Anyway, I digress from the O.P.
Yes your bike will benefit greatly by loosing the cats, just keep them 'in case'.
Hell no you don't need that cat!!!! Thats what I thought back in 76 when I bought my first corvette. Who would've thought that Pennsylvania would start emmissions testing for annual inspections shortly thereafter??? Don't worry about it, drill it out, throw it away, change pipes, no problem. They'll never do emmissions tests as part of the inspections on motorcyeles. Hey, thats what they told me. Don't worry about it. It will never happen. I just put cat converters back on my jeep wrangler today, needed them to pass inspection= $927.00. Don't worry about them, you'll never need them. They will never smog check bikes! Yeah right!!!!!!!
I would just run straight pipes. Don't worry about, they will never ticket you for loud pipes, never. Don't worry about it. Cops will never ticket you for loud pipes, anywhere in the U.S.
Gary D.
Gary D.
Someones bitter!
I really won't worry about bikes being emissions tested,,,,, not at all because life's too short to worry about little things.
I'll gut my cat, love the sound and improved performance of my bike, and IF,, IF they decide to start emissions testing, then I'll deal with it however I have to.. no big deal....
