Speed for 6th Gear on Touring Models
I have an 09 Road King Classic - a buddy of mine told me that unless you're going 70+ miles per hour you should not be in 6th gear. He has a mechanic friend who said the "pin" would eventually be damaged if you did. Just wanted to ask if anybody else has heard this before? If not hopefully this can be an FYI for all of us.
Remind your buddy that the bikes have differences according to year. If it were an 08 and older, then I would say he is almost right (good at 65mph). However, there were changes to your bike to improve on the 6th gear usage. You are are good at 60 mph +. I use 6 gear sometimes if I am just on a flat road and cruising 55mph. Notice the manual recommends upshifting at 55mph and downshift to 5th at 50mph.....but that is just what the manual says
As mentioned above, the gearing is different from the early years with the 6sp to the later ones I think. I am running about 2700 rpm at 75. 2500 at 70. I believe if you stay over 2K in the RPM range your not lugging it. However I usually don't go into 6th until 70+,, I like hearing the pipe!
Even on my '10, I doubt I would run 6th at 55mph though,, unless it was a LONG flat section of highway. And I am not a "Bigger Dude" LOL, only 180 lbs...
