Speed for 6th Gear on Touring Models
Old 08-04-2010 | 08:35 PM
Mick's Avatar
Mick
I ran my first 7000 miles , and shifted into 6th at 60 (single) and 65 (two up).
Engine was happy with these speeds.
I added the SE compensator at 7000 miles and can now shift at 55 (single) and 60 (two up).
Engine is now happy with these speeds.
This would be on flat ground and not a big headwind.
Just listen to your machine and it will let you know what it likes.
My engine is at about 10,000 miles now and it seems more relaxed at lower speeds without balking at all.
Mine is darn close to bone stock and I weigh in at about 156 pounds.
40 lbs front and rear tire pressure , and running a 15" windshield.
YMMV
Mick
  #32
Old 08-04-2010 | 09:26 PM
J2X's Avatar
J2X
I have an '07 and run 6th grade at when maintaining 70 for an extended period.
  #33
Old 08-04-2010 | 09:27 PM
J2X's Avatar
J2X
I have an '07 and run 6th gear when maintaining +70 for an extended period.
  #34
Old 08-04-2010 | 10:52 PM
TOK DADDY's Avatar
TOK DADDY
Good stuff - thanks for the feedback!
  #35
Old 08-05-2010 | 01:10 AM
Devo6684's Avatar
Devo6684
I usually pop her into 6th at or around 65+. I don't have a tach so I have no idea where my rpm's fall in line with the speed. It varies with the grade I am running and so I listen to my motor and shift when she tells.
  #36
Old 08-05-2010 | 10:00 AM
JONNIEROCK's Avatar
JONNIEROCK
Originally Posted by SG 1
Just to keep the debate going, I believe that the HD cush drive 6 speed has a 1:1 ratio in 6th gear which is not a true overdrive. The HD SE 6 speed has a 89:1 ratio in 6th gear which does make it true overdrive.
Just what I have read....right or wrong?
SG 1
You are correct. Thats what I was trying to explain. I really don't know where emwolb got his math from. HD six speed is 1:1. Where as a transmission with a ratio of 89:1 is considered an overdrive meaning overdriven. You can put the smallest sprocket you want on the rear to give it a high output ratio but, it still isn't an overdrive transmission.
Hope this helps Jonnierock
  #37
Old 08-05-2010 | 10:06 AM
Jus Cruisin's Avatar
Jus Cruisin
Mine is happy in 6th at any speed over 55mph.
2013superglideseattle
Milwaukee Eight (M8)
20
08-13-2017 08:33 AM
Granpita
07-19-2013 02:11 AM
rabell
07-06-2013 08:25 AM
Wild Card
08-16-2012 08:36 PM
03psd
07-02-2012 10:33 PM
Quick Reply: Speed for 6th Gear on Touring Models
