Se 120r complete engine?
Old 06-25-2011 | 09:17 PM
otaramc's Avatar
otaramc
Default se120r
Hey Fellas,
It has Been asked a number of times already but the raves on this motor have been too much and now I have to have one :-)
Anyone have info on dealers that stil do 20% off
Thanks
  #462
Old 07-29-2011 | 04:13 PM
itsaw0rkinpr0gre$$'s Avatar
itsaw0rkinpr0gre$$
"Seeker of Freedom"
Looks like they added a FBW 64mm throttle body for the 120RX.
screamin’ eagle
® Pro high-floW 64mm efi
throttle BoDy – electronic throttle
to provide the ultimate results, race engines need all the
unrestricted air they can get. Designed to maximize the
performance of your race Xtreme component-equipped
Se120r engine, this throttle body is ready to take on the
track. the gigantic 64mm throttle Body is precisionmachined
to ensure a smooth air flow when combined with
the Oval-Ported High-Flow Intake Manifold and port-matched
Hurricane Cylinder Heads. Screamin’ eagle
® High-Flow Fuel
Injectors P/n 27796-08
(sold separately) are recommended.
All eFI models require eCM calibration
(priced separately).
for race application only.
27300033
$499.95
Fits ’08-later touring models equipped with Screamin’
eagle Pro Hurricane CnC Oval Ported Cylinder Heads P/n
17799-10 and High-Flow Intake Manifold P/n 27300035
Think I would have put the hurricane heads on, if this were out last fall.
  #463
Old 07-29-2011 | 04:32 PM
speakerfritz's Avatar
speakerfritz
does it have the SE crank case set and the SE crank shaft?
  #464
Old 11-01-2011 | 09:09 PM
TexasBowhunter's Avatar
TexasBowhunter
Considering this as well
  #465
Old 11-01-2011 | 09:12 PM
cardboard's Avatar
cardboard
Originally Posted by otaramc
Hey Fellas,
Thanks
I would try Liberty Harley.
http://www.libertyhd.com/
  #466
Old 11-01-2011 | 09:14 PM
TexasBowhunter
Speak or ask for whom? E-mail address?
  #467
Old 11-01-2011 | 10:22 PM
Dick1964's Avatar
Dick1964
Wow, I can't believe this thread is still alive. Just got an email notice on a fresh post. I started this thread and was one of the first to buy this motor. A lot of people made fun of me. I hope most people are having the same luck as i am. Unfortunately, I may have to sell my bike due to job change, as in I doni't have one.
  #468
Old 12-30-2012 | 04:12 PM
cpooser1's Avatar
cpooser1
3rd Gear
Default 120R problems
You are right about the 120R having a lot of power and torque. It is faster than my Jim's 131 was. The problem is mine didn't last 2,000 miles before one of the flywheels came loose. They are just pinned and not welded. It is Costing me over $2,000 to fix it right, and Harley factory wouldn't back it up. Be careful, I am not the only one to have this problem. My Jim's 131 went over 40,000 before I it b roke with a lifter failure.
Chris
  #469
Old 12-31-2012 | 07:10 PM
buell95's Avatar
buell95
Chris
Can you post some pic's of the crank?
  #470
Old 07-24-2014 | 09:09 PM
metrocrusher's Avatar
metrocrusher
Stage I
Default Motor pic!!
Originally Posted by Inspector 12
Well the SE 120R is installed in my 2006 Dyna, the bike will probably be on the dyno Tuesday. Looking forward to seeing what the numbers are. Here are a couple of pics of the progress.
Hey Inspector 12! Love the bike! Been considering that motor for my FXDB. Would you be so kind as to send me your motor pic that you posted? How does it run?
Top
© 2024 MH Sub I, LLC dba Internet Brands
Follow Us
