Hey all, anyone have one of the Harley Axle Nut Torque Adapter tool? (Usually under the belt tension section of your manual). Its the tool that allows you to torque the rear axle nut without removing the muffler. I am looking for the center to center measurement of the 36mm nut and the center of the adapter for the torque wrench. I am making one and want to keep the correct centers. Thanks in advance.
Distance between centers isn't important, just put the torque wrench and adapter at 90 degrees (perpendicular) and it will work fine.
BTW, there are several other companies making them and they aren't expensive. IMO it isn't worth the effort to make one (and I am a tight ***).
