I've noticed a couple of times on our 2010 RK, that the cruise control indicator will flash red, even when the cruise control switch is in the off position. I've read the owners manual and not sure what to make of this. I am going to call the dealer on Monday, but was wondering if anyone could tell me what might be causing this.
Might mean you're running w/the EITMS (Engine Idle Temp Management System) disabled and bike's running hot...try turning it on to see if there's a change.
That's what I was thinking. Are you accidentally rolling the throttle forward when parking it? This will enable/disable the EITMS.
I doubt that would be the case as the bike is still idling as I park it.... to enable that function bike must be off but with ignition switch on. I will check though
I can turn on and off the EITMS on my bike while it's running. I doubt this is your problem though.
