Cruise indicator flashes
Old 10-08-2010, 06:01 AM
Irish Hogster's Avatar
Irish Hogster
Irish Hogster is offline
Originally Posted by chipofsc
Why would you want to turn the EITMS off? Not trying to be a smart *** but why even have that option of on and off.
Good point!
I've just read in the manual that it comes from the factory with EITMS disabled so I'm gonna go out and turn it on .
Old 10-08-2010, 06:05 AM
PowerFactor's Avatar
PowerFactor
PowerFactor is offline
Originally Posted by Irish Hogster
Good point!
Yeah, I really couldn't see the point of running with it off. My 08 came with it disabled from the factory, too. If I didn't read that in the book (and we all know to read the instructions ), I would have assumed the opposite.
Old 10-08-2010, 10:14 AM
al baehr's Avatar
al baehr
al baehr is offline
I turned nine off because it was kicking on at ever stop light, I keep a eye on my temp and if need I just roll the throttle forward. I have a 2010 flhtk I really think my sensors are not working right but the dealer said it was normal.
Old 08-22-2014, 07:05 PM
IrishMike52's Avatar
IrishMike52
IrishMike52 is offline
2nd Gear
My 2008 RK does the same thing but I can be riding at city speeds or
on the hwy at higher speeds and it will flicker sometimes. Seems like
if I activate the cruise control then turn it off, the flicker will stop for
awhile but then it returns. Everything seems to be working as it should
on the bike. I thought maybe I had a loose wire in the handle bar switch
until I started reading some of these comments. Now I'm not sure???
Old 08-22-2014, 07:55 PM
SafetyMan's Avatar
SafetyMan
SafetyMan is offline
Originally Posted by Swamphunter
I doubt that would be the case as the bike is still idling as I park it.... to enable that function bike must be off but with ignition switch on. I will check though
No, you can able and disable with the bike running. Sounds to me like you are inadvertently rolling the throttle forward while doing your maneuvers.
Because it is not necessary for the engine. Harley has stated this feature is for rider comfort. Nothing more, nothing less.
I keep mine off. I live in South Texas where a "cold front" as described by a weather man, meant a high of only 95.
Old 08-23-2014, 06:11 AM
skratch's Avatar
skratch
skratch is offline
Received 4,272 Likes on 2,492 Posts
i can almost guarantee that that is what you are doing. i say this because i know that i do it all the time. when backing up and turning the bars, i end up rolling the throttle forward.
Old 08-23-2014, 08:53 AM
jstrenn's Avatar
jstrenn
jstrenn is offline
Originally Posted by shortride
The cruise control light will go out after you get up to about 3 mph. The blinking is normal.
The ABS light does that. Not cruise control.
Proudtexan
06-14-2010 07:43 PM
jorswift
06-18-2008 09:12 AM
ltrr1971
06-01-2008 09:09 PM
troutbum1971
05-23-2008 01:56 PM
phxlab
10-15-2006 09:35 PM
Quick Reply: Cruise indicator flashes
