21/18 wheel set up question
I just got my new wheels installed on a 2010 SG. 21 inch in front 18 rear. Problem is the entire bike has been raised due to the tires Im running. 140/70-21 front and rear 180/55-18. Now I have to put on fender brackets to install my stock fender which raises it by 2 inches. If I drop the front end by 1 inch Im running the chance of hitting the fender into the triple trees. The rear cant be lowered using Harley shocks because the SG is already lowered using their shocks.
Any imput would really help out. I would like that lowered look. Plus Im 5'9 and im just flat footing the bike. I can even keep my heels raised.
Hope this info helps. If you need a set of the Progressives, let us know. We have them on sale!
Thanks!
Shawn
You should have went with the Avon 120/70/21 which allows use of the stock front fender by simply drilling out the rear fender mounting holes to 3/8" and rocking the fender forward while tightening it down. I believe you can do the same mod to the front fender and use the 140 front but IMO the 120 looks better.
