HD Air horn bad then good story
#31
put the cooling fan on mine, so I had to relocate the horn.
Got the Rivco's & mounted them on the front highway bar, stuck the compressor in the glovebox - added hogtrough doors to make sure it stays there.
did notice a diffence in sound levels - louder after I added the relay harness.. now it draws power right off the battery.
#32
I had the dealership install the Premium Air Horn on my new Ultra Classic when I ordered it. I have had the bike for 2 weeks yesterday. I noticed the rubber bushing had come loose and the horn was dangling. Is this the rubber that is being referred to in this post? Looked like a **** poor mount. I like the horn, but the mount is no good. How does it mount if the rubber is removed?
Anyhow, the real reason for my post is to see how common this problem is and if anyone knows if a person can just buy that one little rubber plug/bolt piece or if the Moco makes a person bend over and pay $60 for the entire installation kit again?
Thanks!
#33
My apologies to all for resuscitating such an old thread ... but I just experienced the same problem as you did, Rickpeg! I too had a dangly Premium Air Horn on my 2008 Street Glide! My dealer installed the horn when I bought the bike new a year ago last April so it's only about 14 months old. It seemed to happen after a string of mid-90 degree Fahrenheit days so heat may have been a factor. In looking at the rubber bushing, I can see what happened. The metal piece is molded into the rubber and nearly the same diameter as the rubber so it looks like it's more "sandwiched" in the rubber rather than securely encased. I'm wondering if there's any kind of glue or cement I can use that will reliably hold.
Thanks!
Thanks!
#34
Installed the mini beast 2 air horn a few days ago...
Did not have to take off the rubber thing behind the stock horn...
Nor separate the compressor either...
Came with a wiring harness that went to the battery...
5 mins to put the horn on... 30mins or less to wire it to the battery...
Mini Beast 2 Air horn vs. stock HD horn
#36
WTF!!! Three to five hours to install the new horn? There has to be some greater story behind all that. I believe MOCO has an department of making customers life difficult, when doing things by them selves. Just to ensure dealers well being and workload!
In normal life, what, three minutes to take old one of and new one in. Thumbless like me, ten minutes ;-)
