Amsoil experience
#331
#332
If I might ask? Why did you switch to Mobil 1 if the Harley Syn served you so well after the tear down? Personally, I had a leak free evo motor that I ran Harley Dino 360 in and then switched it to the Syn III when it came out. No trouble. Then everyone convinced me to try Mobil I 20/50 Motorcycle oil prior to a trip where it gets hot. Said it was cheaper and better. That evo started leaking after less than 300 miles on the Mobil I and was making a lot of extra lifter noise. My buddy gave me some Amsoil in the middle of the trip and I switched the oil. Motor quieted back down and before I got back home, the leaks stopped. I never looked back and I have gotton 100k trouble free miles on Amsoil motors since. Every motor is different I guess.
I was running the bike though Montana at 95+ for hours in 85+ degrees. After a few days of that; the bike started running like crap. Turned out that the heat and vibration cracked my intake manifold and I ended up frying the rear piston. First year fuel injection and the intake manifolds were weak. When I pulled the motor down, we were amazed at what little wear there was to the motor as a whole and still run Amsoil in both bikes to this day. It a testament on how well the really lubricates and protects against wear.
#333
