Amsoil experience
Old 08-04-2010, 09:28 PM
Quadancer's Avatar
Quadancer
Quadancer is offline
Did he even consider the tighter tolerances of the TC's or any of the new Harleys that are running Amsoil by the thousands? There are mechanics and then there are mechanics.
HiJack: I dropped the unknown syn from my tranny today and put Amsoil gear oil in - WOW!!! Shifting is smooth and quiet as snot on silk!
  #152
Old 08-04-2010, 09:33 PM
07RoadHawg's Avatar
07RoadHawg
07RoadHawg is offline
Originally Posted by lzybt
Redline seems to have the oil fad going right now. I know they have great gear oil. I was told by a mechanic that any synthetic oil in a modern Harley causes piston slap; something to do with it not sticking as well as dino oil to metal parts, and not filling the larger tolerances in a Harley motor.
Good one. Did he also mention that synthetics cause bearing skate because it's too slick?
  #153
Old 08-04-2010, 09:49 PM
beammeup's Avatar
beammeup
beammeup is offline
Amsoil makes it clear that you have to use it's filters to ensure it's touted benefits. Dave used a K&N. Therefore, if there is a problem, you can't come to the conclusion that it was the oil. I'm not saying it wasn't or that Amsoil is better than this or that, but if you don't use it's filters then if something goes wrong you can't say it was the oil. The oil filter is a very important and frequently overlooked part of the oil system.
from what I've read here and there.
great thread though.
  #154
Old 08-05-2010, 12:36 AM
dirtracin23's Avatar
dirtracin23
dirtracin23 is offline
As far as I can tell Amsoils requirement to use Amsoil branded filters is only if you wish to extend your change intervals beyond manufacturer recommendations and want them to stand behind it.
  #155
Old 08-05-2010, 05:42 AM
Jerry1834's Avatar
Jerry1834
Jerry1834 is offline
Well lets see if I have that little noise this morning when I stat it up. I changed the oil and filter yesterday...The oil looked pretty brown (good thing). Its doing its job.
I had 2300 miles to go before the next change out but WTF oil/filters are cheap.
  #156
Old 08-05-2010, 07:40 PM
wayne72472's Avatar
wayne72472
wayne72472 is offline
Default the phone call
spoke with mike from amsoil he said the motor might need a new by pass valve or the filter had went bad. i also told him about this thread, he told me that " we dont thread or look at them" i told him that there were others here that had about the same thing happen to them. also that the oil is check 3 times before it get out of the factory. i was also told if i would email my address to them they would check my oil and see what happen to my motor. i told him that i had the filter which he wants also because they are failing also i was going to give him my address on the phone but he wanted me to email it to him. so i sent my address and now waiting for the oil kit to send back
one thing that made me wonder i ask if the oil could have lost it viscocity and cause itto thin out. he said no i then asked why it would have stopped with the new oil and he said the new oil viscocity was thicker or the filter went bad or something to that effect i was dumb founded and wasnt sure he said that and still not sure i heard him right, now i know that i might need a new by pass valve and got a bad filter from hd.
side note spoke with a friend who is a hd mech and asked how many of those went bad and he said he hadnt seen one yet but he only been working there for a couple of years
  #157
Old 08-05-2010, 08:32 PM
Teardrop's Avatar
Teardrop
Teardrop is offline
Just lika any business they will not admit guilt even if they are............
  #158
Old 08-09-2010, 09:59 PM
mykee's Avatar
mykee
mykee is offline
6th Gear
Just got back from a 3500 mile trip to Texas and Kansas -- I'm telling you, I was really worried about the lifter noise I was hearing from the front cylinder on my 08 Ultra -- especially when I started up after an hour or so cooling, First start up in the morning was terrible until it heated up. WAS using Amsoil 20/50 -- Changed to Mobil 1 V-Twin today, and yes there is a difference... no clatter. For me the Amsoil wasn't getting it done, am really hopeful the Mobil 1 works out and the clatter is gone for good!
  #159
Old 08-09-2010, 11:40 PM
wrongway2's Avatar
wrongway2
wrongway2 is offline
First of all excellent thread.
I'm new to Harley Davidson and at my second oil change I put amsoil in all three holes with the amsoil oil filter as well.
I'm not an aggressive rider but do ride 80 on the highway but never rev the engine over 4,000 even when I feel agressive going throught the gears.
Anyway, I'm getting a bad lifter noise at the high end of the rev range just before shifting into the next gear. I originally thought it was the engine but after reading this thread I'm convinced it's the oil.
I'm 1200 miles away from being due for an oil change but it will be my 10,000 mile service so I'm going to take it to the dealer and have dino oil put in as I'm very curious at this point.
As it stands right now, I'm probably finished with amsoil but time will tell.
As a side note, a friend that I ride lots of mile with has a goldwing and without knowing my concern, is complaining of a lot of lifter noise until his engine warms up. He's also just started using Amsoil so we're both going dino just so we can compair.
regardless, great thread and great forum for this newbie to harley.
  #160
Old 08-10-2010, 07:47 AM
Quadancer's Avatar
Quadancer
The dino oil will be quieter. That does not mean it's better, it's a different animal, on a molecular scale. Clatter does not necessarily mean wear.
LOUD clatter I would worry about. At present, mine has about 12,000 on it and it's second Amsoil change. I have some clicking in the upper end; to be expected with syn - but for cost reasons, I was considering Mobil1 or the VT. Seems that the VT won't even be necessary in the oil tank.
Quick Reply: Amsoil experience
