Help changing fork oil
1 Post
Your left side fork is the cartridge type, and you pretty much have to take them apart to replace the fork oil. The right side is the standard type and should be easy to change out the fork oil. I changed out my left side fork so it's the same as the right side. It will make it easier to swap fluids.
Not sure if it was a year by year change but the forks on my 01 EGC are the same on both sides. Just rebuilt them about a month ago. Each one holds 9.7 ounces.
Unless you took them apart completely which involves removing the bolt from the bottom as it was mentioned you will have to compress em to get all the fluid out.
Silly question but you do have the front end off the ground right? Just asking.
tombeving It will make it easier to swap fluids. UMMM we are talking about fork oil here right?
Unfortunantly it sounds like your only alternative is to possible remove the forks and take them apart...
One more thing would be after you put in those few fluids will it drain after a long period of time?
If so set up some type of a hanging apperatis to hold the fluid with a hose running down to the fork and allow it to drain in there by gravity over night...
paul
Paul, you have solved my problem. ty ty ty. Here's what i did, went to the hardware store a bought a 3/4 garden hose adapter with a 3/8 vinyl tube barb. Bought 3 feet of clear 3/8 vinyl tubing. got a fitting to match the top of the fork with a 3/8 barb attached. hooked it all up to a pint bottle with approx 9.7oz fork oil and suspended it from the ceiling. poked a hole in the bottom of the pint and VOILA...instant slow drip IV for a Harley. it does go slow but works like a charm. Thx for all the help guys.
