Checking air in rear tire... Any Tricks??
#52
I use some small hunks of furring and place one under the sidestand foot too. The rollers also make it easier to adjust rear tire pressure after I finish the blowdry but I've got different mags too (not the standard closely spaced ones) so I don't have as much to overcome as some of the guys do.
#53
#54
#55
I agree. The clip chuck works well and then doesnt work well. A screw on type would be great. Just like the suspension pump for the rear. Ill keep practicing. My hands are so freaking big it makes any jod tougher.
#57
I don't trust dealers with my car tires or my mc tires. Next morning after getting any type of service, I check the tires myself. Never fails, always too much air, sometimes way too much.
#58
Dang... first of all, thank God it's not just me. I thought I was being a wuss.
Next, this is one of those things you're SUPPOSED to check EVERY TIME you ride, so IT SHOULD BE EASIER.
That EZ-Air thing looks great- it's not just checking the air, but allowing the attachment from the pump. But if it doesn't hold up well, as the last few posts suggest....
I guess I'll resort to hjust removing the right saddlebag. Oh, well.
#59
The easiest gadget for me was an idea from this forum. I bought an automobile hand pump from the auto section at my local Wal-Mart; about $8. Bought a small hose clamp to fit the hand pump hose and then went to the tire department and bought a tubeless tire stem, longer the better; @ $1. Cut the hose off of the hand pump at the base, stripped the tire stem back to the metal, pushed it inside the hose from the hand pump, and now a perfect device to check and fill air on my front and back tires.
#60
I bought the HD air pressure gauge and I use it every time I wash the bike.Which is at least every couple of weeks.When I wash it I always use my little scissor lift and that makes it easy to find the valve.The HD gauge works well because it has a 90 deg fitting on the end.But I'm having trouble finding a true 90 deg fitting for my compressor.
