Checking air in rear tire... Any Tricks??
Old 07-30-2010 | 10:21 AM
Homebrew101's Avatar
Homebrew101
Originally Posted by gmc
+1, this makes it much simpler to fill since you can attach the air hose to this after this is put on the tire valve
  #42
bmorebhoy's Avatar
bmorebhoy
Whatever you decide on, it needs to work while out on the road when you need air and I've found that 75% of the gas station air hoses are not angled and I was unable to get the hose on the valve securely.
I find a right angle chuck on the gauge is essential. But when you need air, the home rig in post #11 or the EZ-Gauge in post 33 would work best.
I have the RK Classic saddlebags which are easy to remove, and the H-D filler strips between the fender and bags so there isn't a lot of room to get at the valve but if I remove the bag and get the valve at about 10:30 I can reach in between a gap in the filler strip and not have to lay on the pavement.
Remember to check your air pressure cold.
  #43
Old 07-30-2010 | 10:23 AM
CHOPPIN' CHARLIE's Avatar
CHOPPIN' CHARLIE
Wow! How could a simple PSI check be so complicated? But it is a bitch to do and I see several excellent solutions that sound & look great. Wish I had axed you folks this for outstanding help but I fount out a way all by myself. Spoke wheels & saddle bags on Beloved Heritage. I axed the H-D parts guy what their shop used to check & bought it. A 30$ gauge with the flex hose & angled nipple makes it a breeze. On the dial face it has the beautiful H-D logo. Also it has a probe to check depth of thred depth. Made in China! I go to shop and requested a check psi with their gauge & nice folks brought out a gauge like mine & they were exactly same. 30.$ benifit. Now, one time I was polishing "Black Beauty" & tire needed a 1/4 rotation or so and staying on my stool I started pushing same "BB" & the jiffy stand retracted & Darlin' laid down on me & I couldn't move her. Wife got 2 neighbors to set her up. She said I screamed like a girl & I had to use a walker for 6 weeks!! To keep me from killing myself, I ordered a Motorcycle Wheel Cleaning Stand. Small unit with 2 rollers & tire sits between them and tire can be rotated with one hand. Harbor Freight advertises @19.$ but delivery price @ 40.$. Read the fine print. This is the way that works for me.
  #44
Old 07-30-2010 | 10:32 AM
Dave2261's Avatar
Dave2261
I use this Chec-A-Spare hose. Simply screw it on then check the pressure.
http://www.amazon.com/Accu-Gage-Accu.../dp/B0006O2S8M
  #45
Old 07-30-2010 | 10:35 AM
Leftcoaster's Avatar
Leftcoaster
How 'bout a 90 degree valve stem from www.kurveygirl.com ? No fancy (and spendy) HD tools required for these. Also there are 90 degree valve stem extensions available here: www.dual-star.com
Most run in the $5-$15 range (although the fancy aluminum jobs cost a bit more).
  #46
jsciullo's Avatar
jsciullo
Has anyone tried the EZ-Air Tire Gauge (Model# EZ-Air) on the '09+ RKC? I think they used a different wheel and Im not sure your can fish that straight air line connection to the air valve. Its real tight in there. If that works - its a great solution.
Jim
  #47
Old 07-30-2010 | 10:46 AM
DPete's Avatar
DPete
Big Kahuna HDF Member
Doesn't really apply to the thread but I keep the balance dot on the tire where the stem is painted with a paint pen, easier to get the stem down that way
  #48
Old 07-30-2010 | 10:55 AM
gmc's Avatar
gmc
Found it cheaper on Amazon 17.50 w 5.34 shipping total 22.84. When I bought mine I check w the Mfg. why they don't use a 90 degree chuck and he stated they don't work as well.
http://www.amazon.com/G-H-Meiser-EZ-...0505235&sr=1-1
  #49
Old 07-30-2010 | 11:01 AM
Sweetbaboo's Avatar
Sweetbaboo
I use one of these with my air compressor in the garage; I got it cheap at Walmart. Mine has a blue handle, which might be a Walmart thing, and it cost me about $15.00. I have an 09 EGC with laced wheels so this works very well for me. I also steal the old ladies gardening knee pad to kneel down on; it's the getting back up part that's getting harder these days.
Attachment 130446
Campbell Hausfeld MP6000 Pistol Grip Heavy Duty Tire Inflator w/ Gauge
Multi Function Inflation Tool
Combined inflation gun, air chuck, and pressure gauge
Built-In Pressure Gauge
Easy-to-read pressure gauge measures from 10 to 100 PSI
Clip Chuck Design
Securely fasten air chuck to tire for hands-free use
Built-In Relief Valve
Quickly Reduce pressure in over inflated tires
  #50
Old 07-30-2010 | 11:09 AM
Sweetbaboo's Avatar
Sweetbaboo
Cool! I'm going to get one of these for on-the-road use.
Quick Reply: Checking air in rear tire... Any Tricks??
