Checking air in rear tire... Any Tricks??
Old 07-29-2010 | 07:59 PM
Jack Straw's Avatar
Jack Straw
Hey, someone it!
Thanks for the pics and info there TooEasy.
Old 07-29-2010 | 08:23 PM
IndyClassic's Avatar
IndyClassic
Originally Posted by PWFD
Just picked one of these up over the noon hour: http://www.harley-davidson.com/gma/g...bmLocale=en_US
With the 90' angle this should hopefully help?.
Not too big on HD gadgets but that does look like a nice, easy to use gauge. My 08 RKC has the standard chrome wheels and the stem sits at a 45 deg angle, very easy to access (still laying down). My wife's 07 RKC has the smooth "profile" laced wheels and they are a PIA. straight up and short stem. Hard but not impossible to get the angle so the rotor doesn't stop the gauge stem.
Old 07-29-2010 | 09:15 PM
MNPGRider's Avatar
MNPGRider
The easiest way I've found to check both front and rear is with the Harley shock air pump, which screws onto the valve stem without losing air.
If the tire needs air, add a bit too much, attach the shock air pump, and bleed it down to the right level which is indicated on the gauge, remove pump.
On the front tire, I run the hose from the pump through the slot in the brake disc, with valve stem at 5:00 position.
On the rear, remove the right saddlebag, with valve stem at the 7:00 position.
Old 07-29-2010 | 09:21 PM
SICKBAGGER's Avatar
SICKBAGGER
Oh yes you have to check that religiously for sure. What I do is have the wife bend over and check it everytime and find myself multi tasking like you have never seen right there in the garage!
Old 07-30-2010 | 12:34 AM
emwolb's Avatar
emwolb
i searched for something that would be the easiest and most convenient to use. i ended up buying the harley one with the flex hose. it's about the easiest one i've used. a similar one can be found through jegs or summit racing for a lot less money. when they designed the wheels for the 09 touring bikes with the cast wheels that don't have enough room to check the air, what a screw up on harleys part. if i had those wheels i'm sure that me and the die grinder would have some kind of fun cutting a relief to where a real air hose can actually fit in there.
Old 07-30-2010 | 12:49 AM
leadman's Avatar
leadman
Quickest way to me is to take off the bag.
Old 07-30-2010 | 01:15 AM
hogrider09's Avatar
hogrider09
The rear shock pump. That would be the one for the air suspension in rear . It looks like a mini pump with a guage, right. The threaded end pulls away. Yes, the 28 spoke wheels area bitch. Thats why I went to laced wheels. I like to get a custom 6 or 10 spoke wheel.
Old 07-30-2010 | 04:30 AM
captharley's Avatar
captharley
Go down to your local camping trailer dealer and get a valve extender. They make one out of rubber for about 12 bucks and another with braided stainless for about 22 bucks. They are about 4" long. Screw it on the valve stem - check and add air and screw it off. The way it's designed you will not lose any air when you remove it. I also use it to check and add pressure to the rear shocks. Got tired of standing on my head and never being really sure of the pressure.
Old 07-30-2010 | 05:53 AM
RangeRat's Avatar
RangeRat
Does anyone besides me have/use something like either this:
($29.99 at Harbor Freight)
...or this: ($39.99 at Harbor Freight)
...to spin and wash the rear wheel/tire?
Old 07-30-2010 | 06:08 AM
Iceman24's Avatar
Iceman24
Originally Posted by fireaxxe
Get the HD tire pressure gauge its worth it.
Got mine this month for birthday & usually check air while bike's on jack while cleaning (adds clearance).
Quick Reply: Checking air in rear tire... Any Tricks??
