Going to be installing my dresser duals here soon and was wondering if there are any local places I can get these plugs for the O2 sensor ports? I have a PC-V so the O2 sensors are not needed.
Any particular material these plugs need to be made of?
I haven't tried this, but others have reported that a Toyota drain plug (#90341-18016) will work as an O2 sensor plug and it is very inexpensive. Use some anti-seize compound on the threads before installing just in case you want to reinstall the O2 sensors some day.
You might want to run a tap through the sensor holes. My pipes had been drilled/tapped and then chromed. I was unable to get the plugs in untill i tapped them out. They are 18x1.50 The standard spark plug size
