Twin Cam Heads
Twin Cam Heads
Is this fact? All Twin Cam Heads are interchangible?
All Twin cam Heads are interchangible. A 96" is an 88" Stroker.
You have to use the intake collars that go with the heads or the intake will not line up...
Make sure the collars fit w/o hitting the heads...or you may have to grind to make them fit...
If you use shaved heads...you have to take some off the intake or it will bind on the heads...
Thanks for help.
Thanks for help.
Thanks for help.
Thanks for help.
You can shave some off the heads and still use a bone stock intake manifold. Not sure what the limit is, but my intake is stock and my heads have been clipped. Probably need to talk to one of the head porters to find out what the actual limit is.
Zach
LenBoyLo
Engine Mechanical Topics
11-16-2016 08:45 AM
