Getting the Itch for More Power!
Old 07-25-2010, 07:35 PM
atrain68's Avatar
atrain68
atrain68 is offline
Default Getting the Itch for More Power!
I hope this is a passing phase, but after the cam upgrade over the winter, I've been paying more attention to the big bore posts. A 107 or 110 kit might be a good place for me to start. I'm concerned about some of the issues like pinging or losing any comfort on longer trips. It looks like S&S and GMR have some good kits out there! I'm looking for more torque in the bottom and mid-range. I don't know what I'm going to do. Just when I think I'm done for awhile, I read this forum and get that itch!
Old 07-25-2010, 07:40 PM
Mike's Avatar
Mike
Mike is offline
I've been a hot rodder my whole life, and if more is good, then lots more is better and too much is just right.
Old 07-25-2010, 07:41 PM
bluegrassboy's Avatar
bluegrassboy
bluegrassboy is offline
I'm going BIG real soon......
Old 07-25-2010, 07:52 PM
masterblaster's Avatar
masterblaster
masterblaster is offline
Well you could get the S&S 106 BB kit ($560)and do it yourself, took me a day, next one will be quicker. If you dont raise compression dont worry about pinging. I have your cam thread tagged, you took longer to hit this stage than I thought you would.
But if ya want "all in" read this thread and think about it a while.
https://www.hdforums.com/forum/touri...new-motor.html
Old 07-25-2010, 08:01 PM
EasternSP's Avatar
EasternSP
EasternSP is offline
Veteran: Marine Corp
Received 24,872 Likes on 9,333 Posts
There's nothing better than big displacement and a deep thunder exhaust tone. Be sure to get good head work and a competant dyno tune.
Old 07-26-2010, 08:22 PM
atrain68's Avatar
atrain68
atrain68 is offline
That price looks pretty good! Did you have any work done on the heads? As soon as I put the new cams in, I knew I would eventually crack and start planning for more power! It's going to have to be a winter project though.
Old 07-26-2010, 08:25 PM
TheShrink's Avatar
TheShrink
TheShrink is offline
If you are going to do any type of big bore, do not short change yourself and skip the heads. A nice port, polish and valve job will make the motor very happy.
Old 07-26-2010, 08:52 PM
THABULL's Avatar
THABULL
THABULL is offline
That S&S 106 kit is looking very good to me , right now I'm trying to decide whether to use the SE255 cams I have now with the kit or go with a different cam!
Old 07-26-2010, 08:58 PM
cmcsns's Avatar
cmcsns
cmcsns is offline
Location: Beverly Hills, Fl. Swimmin pools. Movie stars
Had my eye on the TW6-6 for quite some time and had told myself that's all I'm gonna do; 96" is more than enough, just needs a little 'tweaking', right? Long story short, went with Steve @ GMR's 107 kit and I'm enjoying the hell out of my bike now, nice low compression build (10.1), runs strong from just about any rpm or gear. Steve was a good guy to deal with and I've got no complaints; would definetly do business with them again and probably will
Old 07-26-2010, 09:12 PM
07RoadHawg's Avatar
07RoadHawg
07RoadHawg is offline
Good luck on the "passing phase" part..... I'm sure you don't have to ask how I know....
Compression increases aren't an issue (relatively speaking) if you plan for it. Your 6-6 cams like it around 10:1 or slightly over so a 107" set to 10:1 would be a good way to go. Whoever is doing your tune should be able to dial it in so pinging isn't an issue.
Quick Reply: Getting the Itch for More Power!
