Inner Cam Bearing
Inner Cam Bearing
So the front Inner Cam Bearing took a "crap" on my 2005 Ultra w/ 30k miles to the point where there aren't any needles left in the bearing housing. I found some needles in the oil pump & oil pan. I would like to order the Herko Conversion Kit; but I assume that there are probably more needles inside the case. Has anyone had any luck with just "flushing" everything without "splitting" the case then installing the new kit/parts?
I am not sure you could efficiently flush the case out as there is no drain on the bottom. Also, if that bearing went bad then there will be fine metal particles from the grinding of the cam journal and bearings throughout the engine. As bad and as expensive as it sounds, the only way to fix this without later on causing much more problems is removal of the engine and complete disassembly with the cases, head, pan and other large parts being boiled out. Would probably need the oil pump replaced along with most or all of the bearings.
used oil analysis
So the front Inner Cam Bearing took a "crap" on my 2005 Ultra w/ 30k miles to the point where there aren't any needles left in the bearing housing. I found some needles in the oil pump & oil pan. I would like to order the Herko Conversion Kit; but I assume that there are probably more needles inside the case...
A Moco re-manufactured engine sounds like a great choice, if you are satisfied w/ stock configuration. An engine specialty shop might know how to improve on that, though. Gear-drive cams might be a nice upgrade while it's apart.
Is there anything in your riding or maintenance history which may have led to or foretold this failure? Wondered if you inspect the oil-filter debris, if you change your own oil, and which oil you have been using?
