255 cams
Old 07-25-2010 | 11:40 AM
highmark1's Avatar
highmark1
Default 255 cams
looking for torque from 1500 up to 5000 as I dont ride any higher in the r's than that. Looking for bolt in before sturgis to pull the SO and bushtec. 2010 Ultra with T-max TBW, se a/c and V and H pro pipe HO. Don't need high hp just TORQUE. 255's? woods tw6 looks like higher in the range than I like to see the touque. Andrews? not looking to go bigbore yet or even at all if I get the results I want, I will just stay 96". suggestions thanks
Old 07-25-2010 | 11:53 AM
cuda67bnl's Avatar
cuda67bnl
The TW6 doesn't really come on til about 3 grand in a stock motor. The 4* gear will bring it on a little sooner. Great cam though.
Old 07-25-2010 | 12:05 PM
hougz79's Avatar
hougz79
Wow, all the Search ***** must be sleeping in today.....
Old 07-25-2010 | 12:22 PM
highmark1's Avatar
highmark1
search ***** only as good as the info available to search for. I don't really care about somebody's dyno butt but a true dyno sheet is useful to me. So far I have yet to see a consistant dyno chart for SE 255's and everybodys opinion on hp cams not torque cams. HP means nothing without torque and it seems everybody is more interested in HP, which means higher in the rpm's, than torque. 90-100 ft/lbs in the 1500-5000 rpm range is useful for day to day riding in a touring bike not dyno wars
Old 07-25-2010 | 12:27 PM
cuda67bnl's Avatar
cuda67bnl
Here's ya a dyno sheet with the 6's.... my motor isn't stock though, so won't be much help.
Old 07-25-2010 | 12:45 PM
highmark1's Avatar
highmark1
thats some torque info. Thanks. Are you running it 4* retarded or just straight?
Old 07-25-2010 | 12:55 PM
cuda67bnl's Avatar
cuda67bnl
Straight up. The head work and pistons are set-up to run the cam straight up, not advanced. When the motor was stock, I also ran it straight up. Pulled great, but didn't really come on til about 3 grand. Comes on a little earlier now with the added compression. Have a look in the "dyno numbers for baggers" thread, and you can see plenty of sheets for comparison.
Old 07-25-2010 | 01:35 PM
Mike's Avatar
Mike
SE255 are probably the best bet for a torque cam in a stock 96. They were designed for 9.2:1 static compression motors. Bolt them in, tune it and go riding.
Old 07-25-2010 | 01:50 PM
Dalbergia's Avatar
Dalbergia
As has been said and shown many times before, the SE-255 is great in a TC-96...
Attached Thumbnails 255 cams-dyno-tc-96-se255-seac-mo-final-small-noname.jpg
Old 07-25-2010 | 07:01 PM
emwolb's Avatar
emwolb
from what i've seen, the 255's seem to have good low/mid rpm torque and power.
SA66
Engine Mechanical Topics
19
03-23-2019 11:43 AM
InthewindMN
10-19-2015 10:03 AM
Kennyboy62
09-08-2012 06:32 AM
troop
01-30-2010 06:04 AM
harley-jones
11-20-2009 04:14 PM
Quick Reply: 255 cams
