Anybody installed the JM acoustic pads and had noticible results?
Anybody installed the JM acoustic pads and had noticible results? is it worth the ahstle fo ordering and installing?
Here is the link:
http://www.jmcorp.com/ProductDetail....SAP-HDCL&PF=43
Here is the link:
When Dr. V-Twin installed my J&M amp, they removed the padding that had been previously installed with my J&M 7.25" speakers, and replaced it with the J&M acoustic padding. It was hard for me to tell a difference in the padding because the sound was so much stronger with the amp. However, Shawn at Dr. V-Twin had indicated that they felt the J&M padding was worth it based on the installations they did. If Shawn reads this thread, maybe he can comment.
I just put them in while I had the batwing off anyways. I've heard both good and bad things about them.
I didn't notice a difference.
They're no trouble to install, though. They go on easy, adhere really well, and putting the batwing back on is no problem with regards to fitment.
Cannon
Cannon
Same experience here, same reason, was making Hog-tune upgrade anyway, had no trouble with install either. I didn't notice a difference either. Didn't affect fitment at all. I had already done the farring speaker upgrade and was doing the tweeter pod install. The idea made sense, cost wasn't too much, so I figured WTF.
Nate
Didn't install the foam when I upgraded to the J&M's. I previously had installed some type of acoustic rubber squares that firecap had recommended so I just left it in there. Still have those foam pads sitting in my garage.
Damn, just cicked that link, $37.00???? If you want to send me $25.00, I'll ship mine to you.
I have used the foam pad before and could not tell much difference. The last go around I used dynamat instead of the foam. The dynamat was thinner and makes putting the fairing on easier. I think it makes a little difference. If I could not get dynamat from the shop for nothing, I do not think I would use it eathier. It does look cool when you remove the outer fairing, helps to impress all your buddies, LOL.
2004Sierra
03-16-2013 03:43 PM
