Trying to make stock mufflers louder
I took my stock mufflers from 05 and drilled two 3/8 holes in each baffel. I put them on my 2010, and I can't tell the difference between them and the stock. No defference at all. Very diappointed. I thought I'd save a little money by drill them out, rather than buying slip-ons. I guess the cats really chock it down.
How many miles do you have on the 2010 stock mufflers?
The reason I ask is that my '09 stockers got a bit louder around 5,000 miles and then a bit deeper around 9,000 miles.
On my last bike 2006 FLHT (long story) I had drilled the stock 2006 Catalyst mufflers with a 1" drill and removed the catalyst from both.
They actually did sound pretty neat , but had an "odd" tone to them , kinda like small straight through baffles.
I saw a neat setup which has a satisfaction guarantee that I'm thinking of if I were to go louder.
Here's a link.
http://www.americancustom.com/
Even the quietest setup has to be a tad louder than stock with these.
Stock look , and custom tunable sound , for a decent price.
Pretty neat setup.
Mick
Here's a link.
Pretty neat setup.
Mick
We just did this on my buddy's bike. It sounds good.
If my memory is workin right the mufflers on the touring models have 2 baffle plugs in each muffler. Did you drill both of them? Mine had that done & sounded ok but still not as good as the V&H basics that I replaced them with. Did the same on the 1200 Roadster the wife used to ride & it barked pretty good.
Here's a link.
Pretty neat setup.
Mick
Here's a link.
Pretty neat setup.
Mick
I am fairly sure to get any real sound out of a stock head pipe on a 10 you'll have to perform surgery and gut the cat. Then there is a company whose name escapes me that will recore your muffs to what ever level you want. Gutting the cat is not a huge deal. I fully intend to get mine done in the next few weeks.
You'll take the head pipe off. Cut it through the cat. Then reweld it with the pipe alligned up. (Not critical, since the muffler rotates on the pipe for alignment) and should be easy enough with the pipe being elongated at the cat anyway.
I say this because I didn't start mine without the SE Nightstick on it, but others have said they started their bikes, (SG) with no muffler and it still wasn't very loud...
