Kuryakyn Run-Turn-Brake module
Old 08-30-2006 | 12:39 AM
RonH's Avatar
RonH
Default Kuryakyn Run-Turn-Brake module
Just put the Kuryakyn 4859 Run-Turn-Brake module in my EG. For only $69 this thing is great! Just pop the seat and plug it into the light harness and it's good to go. Didn't need the load equalizer either - everything works fine. It makes the turn signals also running and nice n bright brake lights. And they all also flash bright several times before staying bright when you apply the brakes.
Old 08-30-2006 | 01:00 AM
Sreynold1's Avatar
Sreynold1
Default RE: Kuryakyn Run-Turn-Brake module
Ron...Where did you get it? Mail order, local dealer, ETC.
Old 08-30-2006 | 01:04 AM
BadX's Avatar
BadX
Harley makes one also that is a simple plug and play deal. I installed one on the wifes bike and changed out the stock rear signal bar with a Doss bar with kury LED's and works great, so when I got the SG did the same thing except kept the stock lights and just changed to red lenses.
Old 08-30-2006 | 01:23 AM
RonH's Avatar
RonH
ORIGINAL: Sreynold1
My local dealer had one. Took all of 15 minutes to put in, and that cuz I had to remove my adjustable back rest bracket to get to the light harness. Great unit. I had read on this forum that the HD ones do not make the brake lights function bright enough to really do any good, so wanted to try the Kuryakyn - nice and bright.
Old 08-30-2006 | 11:18 AM
ricoman's Avatar
ricoman
good choice
anything to make you more visible is a good thing.
Have noticed several riders in my area have done this but failed to change the turn signal lenses to red. When they brake they show one red in the center and two amber- kinda dumb IMHO.
Old 08-30-2006 | 03:03 PM
Bruce00's Avatar
Bruce00
ORIGINAL: RonH
ORIGINAL: ricoman
good choice
You should see the full LED setup from Kuryakyn
Well worth the $$$$$$$$$
Old 08-30-2006 | 03:28 PM
BIGSKY_FLHXI's Avatar
BIGSKY_FLHXI
ORIGINAL: Bruce00
ORIGINAL: RonH
ORIGINAL: ricoman
good choice
That is what I have......The full shabang...love it. BTW, the Harley module does not flash like the Kuryakyn.
Old 08-30-2006 | 06:18 PM
RonH's Avatar
RonH
ORIGINAL: BIGSKY_FLHXI
My buddy has the full Panacea set up and it's amazing - but way outta my price range. That's why I posted about this set up - it's very inexpensive, gives you a lot more light, and flashes to boot! It's a nice alternative for those who don't have the bread for the big one.
Old 08-30-2006 | 07:23 PM
Gunkholes's Avatar
Gunkholes
[/quote]
[/quote]
I also have the full Panacea (rear) set. The guys I ride with say it looks great at night, but during the day, the LED turn signals don't stand out as much as the stock yellow lights.
Old 08-30-2006 | 11:02 PM
redhwk44's Avatar
redhwk44
Thanx for the info Ron, I am planning to add this very unit to my 06 RKC. Nice to get some positive feedback about it before hand.
Quick Reply: Kuryakyn Run-Turn-Brake module
