Help: RUSH Ceramic Headers
Hello all. Hope you're all enjoying the HOT riding season.
I am looking for input on Rush Ceramic Headers for my '08 RG. I am currently running stock headers with Rinehart Slip-ons.
I would like to get some Rush Ceramic headers and keep my Rinehart slip-ons.
My main questions are: Will my Rinehart slip-ons fit? (they are same size as OEM)
Also, how is the sound / looks / performance of the Rush Headers.
My goal is to achieve a nice TD look and keep my Rinehart slip-ons as well as get some more sound (rumble volume). The ceramic is a bonus, as not melting my lower torso is a good thing.
I am not very concerned about a decrease in performance since I'm mostly a sixth gear highway rider anyway.
Thanks!!!
Thanks!!!
Thanks!!!
Thanks!!!
There has been some talk here about ceramic coated headers. I do know that professional drag racers like John Force uses exhaust systems that are ceramic coated from Jet-Hot. I had a set of factory headers coated inside and out for a V8 in a '65 Ford F100. There was a substance reduction of heat close to the headers. The exhaust sound did change a little. I would imagine there would be comparable benefits for having ceramic coated headers on a motorcycle.
I have considered having the stock headers coated.
Or...you could get any set of TD headers & have the entire exhaust ceramic coated. This way you have more options w/the headers (unless set on Rush) & everything will match (color). I did something similar, but kept stock HD header & ceramic coated it along w/my Rinehart slip-on's. Turned out pretty well & ceramic coating was $160 for the works...
I don't have any answers for you except I put Vance & Hines True Duel Headers on the '08 I had and it solved all my heat issuses.
When I did my "SE 103 Stage IV kit" on my current '09 I put on the "RUSH ceramic coated inside and out headers" because I was told the 103s run even hotter, let alone a Stage IV kit.
I now have 1,000 miles on the new motor and head pipes and it seems cooler than the stock 96 motor. So I am happy I changed the headers too.
1DOG,1GLIDE
07-14-2014 03:44 PM
