My Opinions on FuelMoto Package
Last weekend I finished the installation of the FuelMoto 2-1-2 headpipe, Jackpot slipons, PCV with FuelMoto map, and a SE Ventilator A/C on my 2010 Ultra Limited. My observations and opinions are:
A couple of disappointments ---
1. I am a bit disappointed at the amount of heat still coming off of the headpipe. (Perhaps I was expecting more than I should have.) There is an improvement, but the heat on the underside of my leg is still uncomfortable, not unbearable as before, but still uncomfortable.
2. My fuel mileage dropped to 38.57 mpg from 40.8 mpg I had been getting. The 38.57 was on a 300 mile trip mostly interstate driving @ 72 - 80 mph. I think I read on a post from FuelMoto that their stage I should get around 44 mpg, so that is also a bit of a disappointment.
Now for the good stuff ---
1. The sound is fantastic! Much better than I expected. It has that low rumble we all expect from a Harley and it is downright loud when I open the throttle. If you can't already tell, I like the sound, I do. (This is with the regular baffle set.)
2. Power is much, much better than I had expected, or even hoped for. At 60 mph, in 6th gear, I can open the throttle and the response is immediate and definite, whereas before there was only a slight change in sound and I hardly felt any acceleration.
Overall, I am more than pleased with the FuelMoto experience!
Would I do it again? HELL YES!
I agree with FLHXterp sounds like you could use the map switch function on your PCV. Call Jamie and ask him for a rich map you can use when stuck in stop and go traffic and city riding. Your fuel economy will suffer a little but it would drop the heat some. You can also ask him for a leaner map that will increase your fuel economy for those 300+ mile trips. Not sure how much it is to add this feature but it would solve all your problems.
I just did similar add-ons to you a week ago...and got pretty much the same result, although I have not checked the mileage as yet...LTD runs/sounds great across the complete RPM range...good stuff!
I'm sure the added fuel is to compensate for the increased flow thru the cat-less headpipe...probably the default map...
brad
brad
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Hi Red,
Your experience sounds a lot like mine with the exception of the fuel economy. We read so much about how a Stage 1 upgrade cools things down that I think we expect more than is realistic. I truly think my engine is running cooler than it was before I installed FuelMoto's system but my right leg still get plenty warm when the conditions are right. As for fuel mileage, mine didn't change much one way or the other that I can tell. I'm pretty **** about checking my mileage. I always fill er up and reset the trip meter, then do the math, and high 30's is pretty much what I've gotten, before and after the Stage 1. I even try to fill at the same station and pump as much as practical.
Jamie,
I was very interested to read what you said about your data logging info, especially the part about fuel flow and throttle angle at a given speed in 5th gear vs 6th. I've suspected such was the case a lot of the time. Lower rpms don't always equate to better fuel economy. I'll also (as I'm sure many of us will) be watching your site for info on the exhaust thermal blankets and whatever other tricks you've got up your sleeve to address this issue. I've got my bike to a point where the heat is tolerable but I won't mind taking it a couple of steps further if possible! Thanks for all your hard work and great service!
Ride Safe All!
Steve R.
Jamie,
Ride Safe All!
Steve R.
My mistake was to use the jackpot slip-ons on my stock header while waiting for the CAT-less head-pipe to arrive. When I took the mufflers off I noticed the right one had already began to yellow toward the edge - about a 2" band. Luckily most of it was hidden behind the heat shield.
My advice: If you have a CAT then leave the stock mufflers on there until you replace the headpipe.
Jamie is right on the money about the rpms to run at. Even the stock cams have the peak torque above the rpms that you will run at 60mph in 6th. And if running any type of rolling terrain you will see the economy suffer even worse in 6th. I never shift into 6th much below 70mph
I have played with my tuning on the HQ 107 I am running withe the Fuelmoto catless headpipes, and temps are acceptable and I am getting an average of 42.5 mpg, both highway and country riding, 40 mpg city stop and go, so it is possble, even with a big bore engine.
But, these are tweaks to the tuning that are done from datalogging and driving using a TTS.
