Carb swap on a EFI Twin Cam engine
Hello all, I am currently starting a build on a SoftTail. It is a custom stretched "Hurricane" frame, a 2004 HD FLT 88ci Twin Cam engine EFI (unbalanced) engine off of a RoadGlide, and a Ultima 5 speed trans. My question is this: The bike needs to be wired so would it be easier to buy a complete EFI wiring harness from the 2004 RoadGlide and adapt it to this buildm or would it be possible to go from EFI to a Carb?? Is this engine designed to run only on EFI set up or can it be run on a carb??
gb, you can switch from efi to carb, no problem. Here's the dyna tech but his is for an evo, peek around and find the one for an 04. You wont need the harness. Welcome and good luck.
http://www.jpcycles.com/product/383-...=755118&Ns=Non
Here is the list of parts.
I found the parts list in one of my other post, keep in mind this is for my 99 so there is stuff just for the MM EFI:
Engine mount (with slot for choke) ……. 16315-99 $5.51
Choke cable ……. 29229-88B $8.80
Choke elbow ……. 27580-88 $2.18
Choke boot ……. 27582-88 $1.78
Intake manifold ……. 27613-99 $22.43
Manifold seals ……. 26995-86B $1.51 \\; X 2
Seal ring (carb/manifold)…… 27002-89 $4.91
Ignition Harness ……. 32435-00 $104.43
Manifold sensor (MAP) ……. 32316-99 $26.95
Manifold sensor seal \\; ……. 11291 $0.99
Retaining clip ……. 38723-99 $0.13
Retaining clip screw ……. 68042-99 $0.85
Stock Petcock- 61338-94D $53.00
Stock CV40 Carb- 27412-99D $168.00
MM EFI Tank Conversion from Pingel $40.00
Screamin'' Eagle Ignition 32721-01A $157.02
