I believe I have lost my mind....
or at least what little I had to lose......
I dropped my heads off at the Indy shop today to be ported, polished, bigger valves, new springs, and light mill. While there, the shop owner informed me that he had a deal in a 95" set of pistons/cylinders, forged no less, 10 to 1, and a 2006 model 50mm throttle body with CVO injectors already installed. I won't mention price, but yes, it was too good to say no. So, as soon as my heads get back from the porter, I will be "Without bike" for a few days, but, hopefully, a bit more potent when I get it back. Man I hope I don't regret this. What started as a $1,200 build, has now went out the roof. If I don't hit 100/100, somebody's gettin there a$$ whipped!
nogood o~`o
nogood o~`o
RE: I believe I have lost my mind....
With that set up and head work, with the right dyno tune, man you should be very happy, And that 100/100 should be no problem.
ORIGINAL: wnogood
nogood o~`o
nogood o~`o
You are going to love it, just hold on tight and don't be like me and jerk the bars out of your hands when you bang 2nd gear[:@].
Take a look at my sig below, I'm running a half a$$ tune and its hard to beleive it gets even better
Good Luck!!
P.S. its only money...
Good Luck!!
ORIGINAL: eddybo69
What cams are you going with? At what comp ratio should you add releases, and is your "light" mill job gonna get you there?
nogood o~`o
