LCD-200 from Fuel Moto installed on PCV/AT
I recieved a LCD 200 from Fuel Moto yesterday. It took me about two hours to install it. I had to drain and remove the gas tank to securily route the cable from the PCV to the LCD , which I mounted near the throttle. Now I can display TP, cylinder temp, afr's, knock sensing, ignition timing, speed, gears, rpm's, etc for easy understanding of what the PCV/AT is doing. It will even run logs for later review. Also it has the capability to store and change MAPS. I recommend it if you are serious about tuning your bike to the load and the road that you ride. This is not a cure for the "Tweaking Syndrome" but is very good therapy.
