anyone actually done this, advntgs/disadvntgs?
Old 08-29-2006 | 06:04 PM
dawg's Avatar
dawg
Default anyone actually done this, advntgs/disadvntgs?
In THIS ARTICLE from Harleyhog.co he shows of putting a grease zerk in the primary for the shifter shaft. Has anyone actually done this? What are the advantages and disadvantages? Looks like a novel idea, but I don't know if it would even be worth it.
Old 08-29-2006 | 06:12 PM
Panhead_1_9_4_8's Avatar
Panhead_1_9_4_8
Default RE: anyone actually done this, advntgs/disadvntgs?
ORIGINAL: dawg
Looks like a great idea to me. My Wife's FXSTS stuck almost solid over the weekend (after 4 years). I was able to clean it up and and grease it, but the shaft was scored (I'll replace it). When I do ... I'll put a zerk in to. It appears to me that since it has O-ring seals on both sides, some engineer figures it's a sealed unit. Clearly not the case.
Old 08-29-2006 | 06:17 PM
eddybo69's Avatar
eddybo69
I think it is a great idea. I have been meaning to do it for several months. I get tired of having to unstick my shifter to hit the next gear.
Old 08-30-2006 | 02:36 AM
Eyespy's Avatar
Eyespy
From: Southern California High Desert, here and there....
On mine, it came with one. It's a 2000. Guess the factory stopped putting them there?
Old 08-30-2006 | 10:28 AM
77Tulsa's Avatar
77Tulsa
Myy 99 cop bike has one too. Maybe the cop bikes have them added on the way out the door? Anyone out there riding 2000 or older non police issue bikes that don't have it?
Old 08-30-2006 | 10:44 AM
jerseyjeff62's Avatar
jerseyjeff62
the grease is a good idea,but it will also act like a magnet for road grit and grime making it worse
Old 08-30-2006 | 11:30 AM
shearpinn's Avatar
shearpinn
My 93 FXSTC, which I sold 3 years ago, didnt have one... that I remember at any rate.... lotta beer has flowed under the bridge. The cop bikes are set up for extreme conditions so it is probably an upgrade. But my curiosity is peaked and I will be looking as I run up on EVOs and police bikes
Old 08-30-2006 | 11:37 AM
rwagon57's Avatar
rwagon57
My 92 FLHS had a grease zirc for the shifter shaft.
Old 08-30-2006 | 02:32 PM
Kahuna's Avatar
Kahuna
I think it's a good idea, but if you get your bike serviced (or self-service), you can add the task of lubing the shaft to your list of tasks. I also agree that having exposed grease will attract dirt, which may be defeating the objective. Plus, excess grease could also get slung onto your primary cover and engine case at high speed. Thus, get burnt or stuck on your engine case.
Old 08-30-2006 | 02:48 PM
Square Dude's Avatar
Square Dude
I put one on my RK. While it was still new it looked like 15 shifters instead of 1. The vibration was crazy. I also replaced the spacer with a coiled spring covered with a rubber boot that keeps enough tension on the shaft that it only looks like, maybe 2 or 3 shifters while riding. My '01 has a grease fitting on the brake pedal which is something else I think they quit doing.
Quick Reply: anyone actually done this, advntgs/disadvntgs?
