2010 18" SG wheel width
Here are the installation instructions from HD. The dimensions are in the parts list.
http://www.harley-davidson.com/en_US...ts/-J04978.pdf
Here is the HD web page with both wheels:
3East_id=2534374309368601&bmUID=1279641187967&bmLo cale=en_US
Maybe I misundrestood, but if you are trying to use the front wheel in the back it will not work... The dimensions are different and there is the sprocket...
Good luck.
Good luck.
Why not just put a SG rear wheel from the appropriate year on the back, and the 2010 on the front?
I have custom wheels on my 07 Rk and the rear 18" wheel is 3.5" wide so I know a 150 will work as far as drilling and taping the holes I also know from my custom wheels that the rear wheel is the same dimension on both sides so there is no offset issues. I would not use a 07 or earlier wheel one because I would want them to match and 2 I want 18's on the front and rear. If you take a close look at take off wheels from a earlier bike with the same size front and rear wheel you will see that the wheels are identical.
