Notices
12V tire pump
Old 07-19-2010, 01:02 PM
Harley_RN's Avatar
Harley_RN
Harley_RN is offline
Default 12V tire pump
Putting my list together for things to take with me to Sturgis. One of the things is a tire pump that you use with the cigar lighter. I looked at one today that I thought I had read about on the forum. It was at Wal-Mart for only $9.00. But, it takes 14 minutes to pump up a "normal car tire at 35psi"
Just wondered which one the majority of the members have ?
Old 07-19-2010, 01:10 PM
xxxflhrci's Avatar
xxxflhrci
xxxflhrci is offline
I use a Walmart el cheapo. I took off the plastic housing and robbed the guts out of it. It is pretty compact, now. It will pump up a motorcycle tire in about 5 minutes.
Old 07-19-2010, 01:14 PM
riteway's Avatar
riteway
riteway is offline
If it takes 14 min. for a car tire then might take 5 min.for bike tire..Will you be in some hurry LOL......I have Walmart pump,No issues. Just hope you don't need it.... Personaly i wouldn't care if it took an hour if it worked!!!
Old 07-19-2010, 01:18 PM
Harley_RN's Avatar
Harley_RN
Yah... I know. I have the upgraded HOG roadside assistance but would rather fix the flat myself. I've seen where other riders had a flat and it took 2 hours for the person to get there. Was just wondering if this was the pump that everybody else was using... Seems kind of cheap for only $9.00.. but heck.. if it works ? Not sure that I agree with you that it would only take 5 mins for a bike tire. Sounds like the pump works on PSI.
Old 07-19-2010, 01:27 PM
piasspj's Avatar
piasspj
piasspj is offline
I have the small "Slime" pump. It would be nicer if it had a gauge on it.
Old 07-19-2010, 01:29 PM
frenchbiker's Avatar
frenchbiker
frenchbiker is offline
I bought the Slime air compressor kit at Walmart for $35 or so. I think it's #50001. It contains the small compressor, several power cables, a tire gauge, a bottle of Slime tire sealant, and a nice carrying case. No gauge on the compressor itself but since none of them are accurate .....
I connects to either the cig lighter or to the pigtail for the battery tender. I just replaced the online fuse on the battery tender cable by a stronger one, I think I put a 15amp. The compressor works fine. I mainly use it to add a few psi if needed but if I had to completely inflate a tire, it would do the job, slowly but surely.
Old 07-19-2010, 01:33 PM
Baffler1's Avatar
Baffler1
Baffler1 is offline
Works off the tender pigtails - nice to know!
Knight2's Avatar
Knight2
Knight2 is offline
For only$9 if it works just once it's worth it.
I think most are using the Slime
Power sport or Super sport.
I just got one @$32
Think it's better built.
Pete
Old 07-19-2010, 02:19 PM
PhatTerry's Avatar
PhatTerry
PhatTerry is offline
Slime compressor is not much money at all and a quality product.
http://www.phatperformanceparts.com/.../0363-0019.htm
Old 07-19-2010, 02:28 PM
nevets61's Avatar
nevets61
nevets61 is offline
Slime pump from Wallyworld.... 5 minutes or so for the bike tire... even if it took 15 I'd rather wait for that than a couple hours for roadside assistance... have plugs and tools and pump, takes very little space in the bottom of the bags...
Quick Reply: 12V tire pump
